Subject: Re: Tips for chipping at trimming station on bander?
1/22/20
MarkB Member
Holzher 1435SE and having a bit of an issue with what seems to be the shoes on the trimming station slightly chipping white melamine. Im having a feeling its the material (this is just plain jane commodity white) but it has just seemed to pop up on a few sheets.
Cleaned the shoes really well and they are nice and clean/shinny. Air pressure is spot on. Its chipping on the bottom face so It really tough to see it as a part is going through.
Any input is appreciated.
1/22/20       #2: Tips for chipping at trimming stati ...
Stewart Member
Commodity melamine does chip like crazy at least in some brands - I've seen that issue before too. I would suspect that changing materials would be your best long term fix but, in the mean time, just make sure your trimmer cutters are super sharp and ride just above the melamine surface. You don't want the cutters to touch. Let your scrapers finish that last little hair line. Your edge quality will greatly improve.
1/22/20       #3: Tips for chipping at trimming stati ...
Sorry Stewart,
I should have been more clear. This isn't any chipping to do with the trimming itself. Its actually on the end trimming station where the chipping is happening. The cutting is fine. But where the shoe that pushes the trimming motor down on its arm, where it contacts the work it's chipping and it's happening on both the leadi in and the lead out. I had originally suspected that there was glue or trash or something on those shoes and I clean them real good and polish them up and the problem is gotten way better but it's still happening a little bit.
The actual trimming is fine.
1/22/20       #4: Tips for chipping at trimming stati ...
Rob Young  Member
Website: nutekmachinery.com
I always hated to deliver the message that the chipping problem at the end trim station was material related, but sometimes it is. There are of course other possibilities as well. How are you sizing your panels? Are you using a CNC with compression bits, a sliding table saw, or beam saw? Don't overlook the possibility that the material is being weakened in the sizing process. The end trim stations on the 1435 weren't the gentlest of end trimming stations. The air pressure settings are extremely important. You said they are spot on, so I'll take you at your word. Looking beyond the regulated pressure, try adjusting the flow controls on the cylinders or valves, whichever location they are on your machine. You can reduce the force of contact by opening them up. Of course, you don’t want to open them so much that the tracer show loses contact with the panel while it’s being trimmed. You should also check the bushings in the linkage. If they get sloppy and you can wiggle the assembly back and forth there is a possibility that the assembly could bind. Edgebanders improved when linear rails and bearing were used on an angle making contact between the station and the panel a little less extreme, but that system has its faults and can still cause chipping and denting of soft veneers.
The horizontal mounted end trimmers used on higher quality machines like OTT, some of the higher end Homag and Ima edgebanders are by far the gentlest way to end trim a panel. Your edgebander is up there in years and eventually you may want to replace it so do your research on the machining process the edges go through on your edgebander. The invisible glue line is only part of the equation when producing a quality product. If the machining process isn’t up to par, you’ll find yourself spending a good deal of time reworking the panel. I’ve referenced a link to a page on NuTek’s site that shows the horizontal end trim stations in action along with other edgebander videos. Scroll to the bottom of the page to view it.
If all else fails find a good Holzher Technician to tune up your edgebander to get the most out of it.
Horizontal End Trim Station
1/22/20       #5: Tips for chipping at trimming stati ...
Thanks for the great info Rob. Parts are cnc with compression. Pressure on the machine I mentioned is just the main regulated pressure. I checked it and the cleanliness of the shoes first. The pressure of both stations (to me) has always seemed a little firm but I've never adjusted the flow controls on the cylinders. I will note their current settings in the morning and perhaps back them off a touch. I've checked the play in the linkage and while there is a very small amount it doesnt seem bad enough to bind but will recheck it as well.
No news that it's an older machine.
I'm heavily suspecting the material having run some other panels with no problem.
I really appreciate the information. Will tweak it a bit in the am and fingers crossed.
1/23/20       #6: Tips for chipping at trimming stati ...
Kirk
Since this hasn't been mentioned yet, here's my 2 cents. Are you cutting your parts on a flat table CNC and using a tab or onion skin so parts don't move? If so, on the second pass of the tool to separate the parts, it may be leaving an ever so slight lip that your end trim blade is catching with it's downward rotation. Try block sanding the lead in and lead out ends and see if the chipping goes away. The lip may be so slight that you can't even feel it so try the block sander.
1/23/20       #7: Tips for chipping at trimming stati ...
daniel wipf
I have had issues with the underside chipping away on the rear cutter. but I found my problem to be the mounting plate was twisted up just a little bit causing the guide shoe to hit the bottom edge of the panel instead of hitting the panel flush. took awhile to figure it out but once I had it fixed I havn't had issues no matter what the material was.
1/23/20       #8: Tips for chipping at trimming stati ...
Stuart Douglas
FWIW, we cut our panels on a flat panel CNC with compression bits, and we flip those parts over to edgeband. We had the problem you described, and could NEVER get it to go away, but only on the router cut pieces. The action of the compression bit, especially if has been sharpened, and the speed at which the panels are cut meant that the edge was "just" our of square. I had trouble measuring it over the thickness, it was less than 0.001" I would encourage you to check into shimming the trimmer station though, that is a great solution. It would take very little to make that change on the bander, and would allow you to run parts face up. Also, try waxing the guides with some "butchers wax" or similar to make them ultra slick, that seemed to halp as well.
1/23/20       #9: Tips for chipping at trimming stati ...
MarkB Member
Thanks for all the responses. Really appreciated.
This morning went over the shoes again and made sure they were dead clean, stoned them very slightly incase there were any knicks, backed the pressure off a bit on the trimming station and the chipping on the first side cut went away immediately, second side got worse. Took Rob's advice and throttled the fall of the second trim slightly and for now the first batch of parts are fine.
Kirk, That was my very first thought when this happened, that the router had developed a knick or was leaving a tiny flash on the bottom side but even flipping the parts it would still happen but still watching it closely. Im trying to address 1-2 issues at a time hoping to find the true cause.
Daniel, I need to look at that a bit next, Im going to put a thick piece of MDF in the bander and make sure those shoes are hitting square to the panel (as square as I can get them).
Stuart, I will hopefully see if the shimming is necessary with the thick part test and checking the shoe alignment. Like I say, its trimming fine, its just the shoe on both trims was chipping out the material where it contacted the edge of the part.
At this point Im honestly feeling like it is some percentage of commodity material, and the trimming station pressure.
Its back to banding just fine at the moment but that can of course go awry in a nanosecond.
Thanks again guys for all the input. Major major help.
    • Machine Bid
    • Lignomat
    • Salice America Inc.
    • Country Saw & Knife
    • American Fabric Filter Co.
