Subject: Re: 3/8 overlay soft close hinges
11/26/20
nicko Member
I'm looking for soft close hinges with a 3/8" overlay. I need 50 of them. Any recommendation on where to buy? I am only finding full overlay and 1/2" overlay at my local supplier
thanks.............nicko
11/26/20       #2: 3/8 overlay soft close hinges ...
Thicker plate with the hinges you normally use?
11/26/20       #3: 3/8 overlay soft close hinges ...
As an example. For partial overlay, it's usually half an inch. I use Blum hardware. A straight arm hinge, with the cup drilled at 22½mm, and a 3mm plate gets me that ½" overlay. If I want to make it .375", I'd just use a 6mm plate.
11/26/20       #4: 3/8 overlay soft close hinges ...
duster
A 4.5 mm plate with a straight arm overlay hinge will do what you're looking for.
11/26/20       #5: 3/8 overlay soft close hinges ...
nicko Member
thanks for the replies. I should have mentioned that these are face frame cabinets. I found Blum face frame hinges but there only make the 3/8 in self close not soft close so i might use the self close hinges
thanks......nicko
11/26/20       #6: 3/8 overlay soft close hinges ...
mike
not sure if i am missing something but the book shows 38N355b.06 is a 3/8 overlay face frame soft close hinge. screw on but press in available
11/26/20       #7: 3/8 overlay soft close hinges ...
Nicko
Mike. Thank you for the info. That’s what I need. Thanks for the help. Do you know if they also make a soft close in a 1/4 inch overlay?
Thanks.........nicko
11/26/20       #8: 3/8 overlay soft close hinges ...
mike
5/16 but not 1/4
    • Salice America Inc.
    • Steve H. Wall Lumber Co.
    • Limtech Industries, Inc.
    • J&P Machines
    • Impact Search and Placement
    • Denray Machine
    • INNERGY
