Subject: Re: Door Reveals are off using cnc and edgebander
9/24/22
Rich Member
Our first vanity project but our door reveals are off . We premill the tape thickness .
I did a quick measurement with scraps of .8mm tape . My reveals are off exactly the thickness of 2 .8mm tape . We premill all sides
Cabinet vision leaves a 1/8 gap all around .
.8 mm tape
Cabinet Vision 2022
Rover k 1531
Holzher 1057 xl c
How can I adjust this ?
View higher quality, full size image (1080 X 1920)
View higher quality, full size image (900 X 1600)
9/24/22       #2: Door Reveals are off using cnc and ...
I don't use CV, but my guess is it's accounting for the banding thickness and you need to set the thickness of the banding to zero in that template?
9/25/22       #3: Door Reveals are off using cnc and ...
JK Interior Finish Inc.
Could be your hinges are not setup correctly, are you verifying the parts to see if they are correct size ?
9/25/22       #4: Door Reveals are off using cnc and ...
Time for some detective work. Recut a door or verify the dimension in CV. Is your dimensional error in the raw part? Next band a known dimensioned square with the banding and re measure. Is the error in the set-up of the premill?
9/26/22       #5: Door Reveals are off using cnc and ...
Jared
There are a few places to check in CV: First, make sure Cabinet Vision knows that you're premilling, and how much you're shaving off: in the S2M Center tab, go to File --> Preferences --> Geometry, verify there's a check in the "Pre-mill edgebanding" box, the drop down box is set to Fixed, and enter the amount your bander's premill station is set to. It will add that amount to the door dimensions. Second, verify your banding material has the right thickness in the Material Manager. Third, verify the material schedule for your door type shows Banding: Yes in the left hand column. Lots of places to get door banding wrong in CV...
