Subject: Re: cabinet installs
cabinet installs
12/10/22
Rocky Creek
When doing installs there is rarely a time when I don't have to trim edges of cabinets to make things fit.
I usually leave 1/4 scribes on unfinished ends, so I have room to trim cabinets to make them fit. If they are short i will glue strips on the end of stiles if necessary. Is this the common thing for installs or is there a better way. I always take the best measurement I can from the shortest distance between to walls.
I have had two kitchens that worked out to where I didn't have to trim anything to make them fit.
12/10/22       #2: cabinet installs ...
Jim
When I use scribes I put a 1/2 X1/2 rabbit on the edge , much easier, planing the 1/4" edge
12/10/22       #3: cabinet installs ...
We add a ½" typically for scribe on anything that is wall to wall. If it's really wonky, we'll add more.
I cut with a circular saw close to the line, then get to the line with a belt sander.
12/10/22       #4: cabinet installs ...
When I measure I check walls for plumb and the floor for level. I work in a lot of older houses that can have astounding problems.
I add the appropriate scribe to the wall cabinets and sometimes to the bottom of the lowers if the floor is crazy enough.
Most of my scribes are glued onto the cabinets. But single cabinets that will be going wall to wall usually have one removable stile so I can fit it in place, scribe one side and then put the other scribe to the wall and scribe it, then reattach using several methods depending on the situation.
At times I've used a detached face frame and glue the face frame on the cabinet after the cabinet has been secured in place.
12/12/22       #5: cabinet installs ...
Like Leo, I also have worked in quite a few old historic houses. Memorable ones were a 15 foot wall that got bookcases and a large central hutch. The wall was leaning 2" in 9'. I did a galley kitchen(10' long island butted into the wall) the floor dropped 3" in 10'. The entire floor was sagging to the middle from the exterior walls. The toe kick was slightly tapered. We typically do an extra 1/2" on the end stiles. Better to cut extra off than be short...
    • INNERGY
    • Denray Machine
    • Limtech Industries, Inc.
    • Forestry.com
    • Sandman Products
    • O'Shea Lumber Company
      Merchants of Fine Woods
    • Better Vacuum Cups, Inc.
    • WalzCraft
