could use some Help psa cracking? -- 0 --
3/7
Hi I am doing a cabinet refacing using psa alder veneer and from handling it with my slitter it keeps cracking.
my guess is because it had been sitting for about 3 days before the install.
I finish using Mohawk 2 coats sanding sealer, sand 320, 2 more coats sanding sealer, sand 320 and 2 coats lacquer.
I know lacquer can get brittle when cured I need to see what you guys are using to keep it flexible until I go to install on a cabinet reface.
Maybe add some retarder to keep it from completely drying underneath? Or is there maybe a flex agent I can add to it? Thanks for any help.
3/7 #2: could use some Help psa cracking? ...
That's a lot of finish. Try 1/1/1 vs. 2/2/2 coats. And keep it thin.
3/7 #3: could use some Help psa cracking? ...
You are putting too much sealer on! One is enough. Sealer is soft. Keep the total thickness build down. Lacquer sets hard. Too much and it will check down the road. It won't be able to move with the veneer. Is this the first time you've had problems slitting paper backed veneer? If the wheels on a slitter wear even a little they will want to bend over the material before breaking it off resulting in the cracks you see. Alder is really weak.
3/7 #4: could use some Help psa cracking? ...
Thanks I will have to try that.
I know that psa comes pre- finished in a rolI wonder if they use lacquer or maybe something different?
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
