zero glue line finish for high gloss laminate & edgebanding
5/1/15
antonio
using acrilux high gloss laminate with matching edgebanding but having problems using contact cement, it shows the glue line. What is the best way to achieve a zero glue line finish without the million dollar holzher equipment?
5/3/15       #3: zero glue line finish for high glos ...
harold morantz
Are you using a bander? We laminate top and bottom and band afterwards. There is no glue line. If you are using contact cement for edgeing, try waterbased H2O from wilsonart. It is white.
5/3/15       #4: zero glue line finish for high glos ...
antonio
thanks, no we are not using a bander, so we are not really equipped for a real professional application, but trying to figure out the best way to get this done without it, i may give that white contact cement a try! thanks
5/3/15       #5: zero glue line finish for high glos ...
harold morantz
I dont know where you are located, but if there is a shop in the area that has a bander,try to rent some time from them. This is a high tech material and you are using old school tecniques. We have a great bander with radius bits and PLC control and it is still a challenge to get a great edge.
5/3/15       #6: zero glue line finish for high glos ...
antonio
i agree, this will be a learning experience for us, i will not install the finished product until it is acceptable. Worse case scenario we will just spray it with white CV. Was hoping i could get this to work so this could be our go-to system for high gloss finishes.
