Williams and hussey question
5/10/15
Mike Fuson
I've got a williams and hussey molder, not sure of the model number but I bought it new about 8 years ago. I've got some feed issues with the out feed roller but I haven't tore it down yet to see what's wrong. Question is, while I've got it torn down I'm thinking about putting new rollers on it and maybe the variable speed motor. Mine has the yellow rollers on it and thinking about going back with the green since evidently they are more durable? Also it appears that they have three different variable speed setups but the only difference is the controller box? Anyone have any experience with these rollers or variable speed units and care to lend some advise as which to get? Thanks
5/10/15       #2: Williams and hussey question ...
Leo G
Can't help you much with the rollers. I have an older machine, the rollers are black. They are slightly torn up from making curved moldings. If you are going to be doing straight runs get the harder roller. Curved moldings get the softer.
I was unaware they had more than one variable speed system. I have the variable speed motor with the external controller box. It uses a 90VDC pulse motor. If you are doing a change over they will also send you some new sprockets for the chain. Well, they did for mine.
Any of the adj speed feeders should improve the molding quality. I believe the original fixed speed was 19fpm which is way to fast for most operations. I usually use my controller at 30-40%. I also lock down the the floating side to get rid of some chatter that can occur running larger profiles.
5/11/15       #3: Williams and hussey question ...
John Langley
Mike I'm not in the shop so I can't look there's also a spring system that will let you make multiple passes I went to their website and I called him and they were very helpful I look to see what color my rollers are , i go out to the shop it seems to me that thay held up
5/11/15       #4: Williams and hussey question ...
Chuck Rankin
Hi Mike:
We stock replacement feed rollers for the Williams and Husssey molders.
Here is a web page link. Please feel free to call us at (828) 628-4414 with any questions.
best regards,
Chuck Rankin
Wood Tech Enterprises, Inc.
View larger image
Williams & Hussey Feed Rollers
5/11/15       #5: Williams and hussey question ...
Dan / drbwoodworks
If you by new rollers , you can send the old cores to western roller and they will recoat the cores with your choice of hardness for a reasonable price . We use the yellow ones , we run a lot of radius pieces. Also we put the variable speed unit that Leo speaks of when they first offered it , and found it to be a good improvement . I believe it also came with larger springs too. It's definitely worth it . I'm not sure where you are located , if you are in southern ct , Ct saw and tool stocks the feed roller also.
5/12/15       #6: Williams and hussey question ...
Russ
Website: http://www.mirror-reflections.com
Please measure from the bottom of the cutter to the start of the profile at the deepest part on the moulding knives, the target number should be 1-1/2" from the bottom, if your are 1/16" to 1/8" of this number it should be fine, but if further from this dimension it could affect your feed rollers ability to touch the product.
Just a thought before you spend any time or money.
All the best
Russ @ MR
5/12/15       #7: Williams and hussey question ...
Mike Fuson
I appreciate all the responses, all were good. The only thing that was wrong with mine was the little Allen screw that holds the cog to the shaft had backed out letting the cog just spin on the shaft, so it was a easy fix. I'll probably hold off a while on the upgrade but at least I now have the info I needed. Thanks again!
