Hole drilling jig for closet systems
7/16/15
I'm in search of a jog that will allow me to set my first set of holes 9 or 9.5mm from the top for doing closet systems
I need a jog that will allow me to drill several holes in a wide array of panel depths being spaced 32mm apart and 37mm from at least the front edge. I would like a jig that will say allow me to drill double row of say 24 holes, slide it down the panel, then insert a pin into a previously drilled hole to lock it in and to be able to drill another "24" holes and so on. Also, would be nice if when it's clamped on, it drills square (perpendicular to the face)
Any such animal? It doesn't and wouldn't pay for me to buy a line boring machine
7/16/15       #2: Hole drilling jig for closet system ...
carbidetooth
I like this one. I imagine I've drilled in the thousands of holes, still works as new.
Lee Valley Jig
7/16/15       #3: Hole drilling jig for closet system ...
Chris
Another good one if you have to drill by hand.
Hafele shelf pin jig
7/18/15       #4: Hole drilling jig for closet system ...
Pat
The Festool hole drilling system is fast, flexible, and the produces factory quality holes using a spiral bit in a router. Can be pretty expensive, but pays for itself if you use it enough. In addition to the kit, you need a Festool router and a special guide rail with holes.
Festool LR 32 Hole Drilling System
7/19/15       #5: Hole drilling jig for closet system ...
Kevin Member
Hire a Shop to build your Closet
7/19/15       #6: Hole drilling jig for closet system ...
Mitch Suber
Website: http://subercustomshutters.com
I have the Variant jig from Hafele that Chris suggested. I really like mine and have been using it for years. Single row only, but no big deal to switch sides and drill that second row. If your material has square ends, the rows line up quite well. Plus, when hand drilling, you can only work one row at he time. To get the right spacing between rows, you have to rip your material to certain widths. First hole is preset for accurately drilling the first hole for cam assembly. Even if you have another shop drill a system for you, this thing is great if they miss something.
7/20/15       #7: Hole drilling jig for closet system ...
Sounds like you need to buy a boring machine! Jigs or Jogs are very slow.
