mixer lifts
9/22/15
Tony
I have a customer who wants a mixer/appliance lift in her island. I have installed these before but have never been completely satisfied with their operation. They seem to be noisy and have quite a bit of slop. Ashamed to say, but I don't remember the brand I have used. I know I had to make a shelf for it. Any suggestions on a quality brand you have used is appreciated.
9/22/15       #2: mixer lifts ...
dustin orth
We use RevaShelf mixer lifts a few times a year and like them. They came out with a soft close version that I saw at the Vegas show and it looked pretty good. As far as slop, your going to have some no matter what brand due to the design of it. I put one in my own house and it makes using one of the big KitchenAid mixers a nice thing instead of a pain thinking I am lifting one of my machines instead of a kitchen appliance! List price looks about $165. Hope this helps. Dustin
9/22/15       #3: mixer lifts ...
Bruce H
I had a customer who wanted one. I gave my opinion but installed it anyway. A few weeks later she called and ask if she could get her money back?... NOT!
I have used the Rev-A-Shelf ones and they were a bit better however if you want the shelf level then the hardware had to be installed out of level. I have programed the crooked hole pattern in the CNC and am ready... (still hope no one wants one)
9/22/15       #4: mixer lifts ...
Tim Schultz
Of course pop up mixer hardware is not going to be as stable as a mixer on the countertop but this hardware can sometimes make the difference between having a mixer and not having one. These things are heavy and as our customers aged sometimes hard to lift up.
There are a couple of things to pay attention to. The first one is that Kitchen Aide makes TWO sizes of mixer. The second one is that Kitchen Aide makes TWO sizes of mixer. Make sure you get the right model number. The one with the side crank is an inch wider than the one that has the motor on a hinge. (Guess how I learned this).
The third thing is front to back placement of the hardware. You can install everything perfect in your shop but the weight of the mixer will cause the platform to shift forward. We learned this, of course, after the cabinets were installed and the customer trying to move in.
For some reason I can only find a jpeg of this PDF but you are welcome to it if it will help.
popup_mixer_1.pdf
9/22/15       #5: mixer lifts ...
Bruce H
While it is not a lift. I make a roll out shelf, on 200# full extension slides, that sits on the counter surface behind a tambour door. This is useful for someone who uses the mixer a lot. There is no open door when the mixer is in use. If someone need to get by the mixer can be pushed back in, easily. It is way more sturdy than any lift I have seen. The downside is it does take up some of the counter space. The unit is 381mm wide x 457 deep and uses a 400mm slide.
