Veneer core and dowels
10/5/15
Carmine Member
We currently use prefinished veneer core ply for our boxes and just pin and screw for assembly. I'm considering the purchase of a construction borer and switching to dowels.
I know this is common system for many but I know many companies use a PB product. Don't know if all the voids and thickness inconsistencies with veneer core will create more problems than I'm trying to solve.
Anyone out there using a dowel system with VC ply?
10/6/15       #2: Veneer core and dowels ...
We have on very rare occasions used VC but it's drawbacks for dowel construction make us avoid it. Like the light weight. Hate the warp, inconsistent thickness, and some problems spreading the plys apart when doweled. We dowel all simple cabinet boxes using a CNC bore & insert machine and case clamp. It is fast, as cases need to stay in the clamp only until the next box is ready. Cases are held square since the back is fastened in while in the clamp. If you do dowel with ply, off set the dowels from the CL enough that you can quickly see which was the reference face.
10/7/15       #3: Veneer core and dowels ...
Chris
Website: http://www.hofmannjoinery.com
Just as an alternative to doweling, check out the Lamello P system. Slight voids in VC ply don't matter because of the width of the connector and the strongback profile. Clamps together super strong and can flat ship with connectors installed.
Lamello System
12/5/15       #4: Veneer core and dowels ...
Geoffrey Wirth  Member
This sounds like our normal process. Almost all our cases and drawers are pre-finish maple ply. We use a Columbia C-2, and have no issues. It's a very smooth process. If my clients liked particle board cores we would use it more. It bores and dowels like a dream.
    Lamello
