Painted countertop substrate
1/24/16
Michael
I am on a built in project that is calling for a painted countertop. I typically install (or other guys install) non-painted countertops either of solid butcher block, veneered plywood, or stone etc. I'm thinking of stacking MDF to get the thickness and just painting it. It won't have any water exposure and not likely to have anything even placed on it. I think MDF would have the benefit of not requiring any edge treatment like edgebanding and can take a profile as well. I'm a little concerned about the edge and top durability. Anyone have recommendations or do this another way? Thanks in advance.
1/24/16       #2: Painted countertop substrate ...
Duster
I've done several painted countertops in mdf, and dozens of furniture pieces with painted mdf as well. I usually use 1" or 1.25" thick mdf. I've never had any problems or call backs. Simple edge profiles without sharp edges work best.
1/24/16       #3: Painted countertop substrate ...
Matt Calnen
If your worried about the edge than apply a wood edge to it. I never liked the edge of mdf being the first thing to take abuse, as in a top edge. I always keep the wood as thin as possible, to keep the glue joint as close to the profile as possible, to better help hide the glue line in the future. Sure I'll make a mdf door, but the edges are mostly protected.
1/24/16       #4: Painted countertop substrate ...
I guess you have experience with sizing or filling the edges of MDF. I hate the way the edge takes paint. If my job, I would edge band it with hardwood, and clear coat the paint for more protection.
1/25/16       #5: Painted countertop substrate ...
Thom
I believe that the mdf edge is more durable in the long run than edge-banding. Several times I have finished the raw edge of mdf even when the faces were veneered. I just sand the edge and profile to 320 grit and it takes finish the same as the pressed faces.
1/26/16       #6: Painted countertop substrate ...
Rick W
You mighty also try MDO plywood. It's stronger and more durable than MDF. You can also edge-band it.
Rick W
