Blum Aventos or similar
2/2/16
Peter Rawlings
Client wants to modify 2 existing open shelves in pantry into lockable liquor cabinet. Has seen Aventos or similar and would prefer vertical lift doors.
I've never installed them and a couple of questions some to mind.
1. What's your impression of Aventos and is there a better option in some other brand?
2. Is the opening movement such that I could use a simple cam lock?
Thanks for any insight.
2/2/16       #2: Blum Aventos or similar ...
Lot of monkey motion for what they do.
I think you would have to use a chest type lock.
2/3/16       #3: Blum Aventos or similar ...
Mark B
I've used Aventos a few times. Pat's right, it's a lot of mechanism to lift a door. But, it's a much better and easier solution than anything else I've tried with hinges and lifts.
2/3/16       #4: Blum Aventos or similar ...
D Brown
You could use pocket doors .
I have used them in the same way and they work fine .
2/3/16       #5: Blum Aventos or similar ...
Dan
Take a look at the Hafele version of the lift up mechanisms as we find them to be a bit better. The "Free Up", "Free Swing",
2/3/16       #6: Blum Aventos or similar ...
Peter Rawlings
Thanks all. Can't use pocket. Only other choice is swinging...not ideal in the space. The vertical lift really would work best in this scenario so I guess I'll get some experience.
Are they stable enough that if I install a long bar pull and homeowner lifts on one end it won't rack the door? Door size approx. 24" wide x 16" high.
2/3/16       #7: Blum Aventos or similar ...
Yes
2/3/16       #8: Blum Aventos or similar ...
Dan
Easily accomplished with Hafele Free Up
