Painted Open Cabinet Interiors
3/28/16
Jarin Smoker  Member
I wanted to see how the rest of you treat open painted cabinets such as bookcases and glass upper cabinets? Does anybody caulk the backs to the sides? The top and bottom to the sides? We spray conversion varnish and it sometimes bridges the gap, but usually there is a fine line/gap between all these pieces. We have not had good success with caulk under CV before, so I am nervous using caulk in between sealer coats. We have a customer right now that is becoming very picky and we had to go back and put a fine bead of caulk after the cabients were installed. The color is Dove white so it is a slightly grayish white without any forgiveness!
Thanks,
Jarin
3/28/16       #2: Painted Open Cabinet Interiors ...
I use caulk between two coats of primer. Then CV over the primer. I use a squeeze tube that I've made a 1/32" hole in the tip. I've done 4 kitchens and still have half a tube left, so you see I'm using very little caulk to seal the cracks.
However, The backs I spray separately and staple on after. I don't worry about the small line there. It is the nature of the beast.
They have tinted caulks. I'm sure if you look around you can find the company that does it. I'm betting they probably don't sell just a single tube though. You'll likely have to by quite a bit.
3/28/16       #3: Painted Open Cabinet Interiors ...
Harry Devrieze
I paint/finish all our backs loose and put them on later. Easier to sand between coats and way less blow back when spraying inside a cabinet box.
Regards
Harry
3/29/16       #4: Painted Open Cabinet Interiors ...
KAP
We finish before assembly... much more efficient time-wise, and a lot easier for prep and sand... you end up with a nice tight joint...
3/29/16       #5: Painted Open Cabinet Interiors ...
JeffD
I spray then assemble as the lines generally don't bother anyone.
FWIW I was picking up some Dove White today at the local Ben Moore place, (am spraying some built up crown on site to see if it's a better solution to pre-painted trim?), Anyway I noticed they now sell tubes of caulk you can tint yourself. You buy the tube, squeeze in some of your paint, (latex only I think), then squeeze in the hardener and your good to go. Haven't tried it but really like the concept.
good luck,
JeffD
