Butt joints in edge tape
5/25/16
Hi All.
Looking for some tips and tricks for getting a nice butt joint when edgebanding a circle. Using 0.5mm tape and contact cement.
5/25/16       #2: Butt joints in edge tape ...
John Member
For one-offs I cut the band about an inch longer than needed. I iron it on but leave about 1/2" unbonded on the first end and about 2 inches unbonded on the other end (3" total length on that end). Then I slip a short scrap piece of edge banding under the 3 inch long piece, butted against the first end. Now I put a combination square over overlapped ends and cut through both unbonded pieces with a sharp Exacto type knife. Remove the scrap pieces and the two ends should fit together perfectly, or might be just a smidge too long, which is good because they will fit together really tight when you iron them down.
John
