Attachimg crown to plaster walls
7/18/16
I have a job I'm bidding cabinetry and i want to see if i can add a bonus in my bid and that would be doing crown in the ceiling of the kitchen, but ive never attached crown to plaster walls. I do know they can be and or are brittle.
I have found throughout the years that in order to prevent the crack line in the caulk at the ceiling from the crown dropping out, is to add full triangular blocking behind the crown and attach the crown to the blocking vs just the drywall-but can this be done the same way without cracking the plaster via attaching the triangular blocking or if i put an 18 gauge nail gun through the crown and into the wall and ceiling itsself
7/18/16       #2: Attachimg crown to plaster walls ...
Mike Member
I have in the past installed a 3/4 by whatever fits cleat around the room that will be behind the molding but not interfere with it, that is they never touch each other. Nail the crap out of it or what ever it takes to hold it secure then when installing the crown you have a nailer that the gun nails will reach anywhere you want or need one.
I usually do this when the crown is big and i can't reach the top plate with 16s.It also allows you to use a smaller gauge nail if the crown is stained.
7/19/16       #3: Attachimg crown to plaster walls ...
Chris
What mike said. Add PL construction adhesive
7/19/16       #4: Attachimg crown to plaster walls ...
Pat
If you're worried about cracking the plaster when installing the nailer, use screws instead and pre-drill.
7/20/16       #5: Attachimg crown to plaster walls ...
Bruce H
We adhesive calk behind trim parts. Usually doesn't come loose easily.
