Sanding dust
8/6/16
Richie Alcorn  Member
Website: alcornswoodworking.com
I've never posted here before but have been looking through the post for years and have gained some ideas and info. Decided it was time to jump in with a question.
We do mostly cabinetry both residential and commercial. We have a good handle on dust collection but I still notice a lot of fine dust around the shop. I'm sure it's coming from sanding with our random orbit sanders, we don't use any type of vacuum or dust collection on those and I'm concerned not only about the dust in the shop but with the health of my employees.
We currently use 5" random orbit sanders that are pneumatic. Do any of you use a central vac system with your sanders, if so what are you using and is it effective. Does it interfere with the sanding operation.
8/7/16       #2: Sanding dust ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
I use a regular small shop vac for all my sanders, works real good with the Mirka Abranet screen type sandpapers.
I have hooks in the ceiling I support the hoses from.
I also run a fan with a pleated filter
on it anytime I'm in the shop.
8/8/16       #3: Sanding dust ...
We use the Festool sanders and the Festool vacuums. The vacuums are large, extremely effective, run when the the tool is on, off when it is off.
There is almost no dust that escapes the vacuum. Both sander and vacuum are expensive, but we have used our two units daily now for almost ten years, and the shop has never been cleaner. We certainly have gotten our money's worth.
8/8/16       #4: Sanding dust ...
Thanks for the response, I think we'll try one to start with and see how that works out. My real concern is that dragging the hoses around would be a pain and the guys wouldn't like them. I think not breathing dust will out weigh that.
8/8/16       #5: Sanding dust ...
David R Sochar
You can get extra lengths of hose and have them come down from overhead so they don't get underfoot. That is an excellent way to do it.
8/8/16       #6: Sanding dust ...
Jesse Fast Member
Website: http://countrysidecabinetshop.net
Have you considered a Downdraft Sanding Table? I can't say enough good about them.
We have 2 Sandman Tables.
SandMan Products
8/9/16       #7: Sanding dust ...
I use a 5" 3M sander with self generating dust collection. I have Hepa dust bags that are disposable. I don't love the idea of throwing away a dust bag after a couple of days of heavy sanding but the collection is excellent. The sander-bag combination is light and compact and no dust hose makes it more maneuverable. It is mainly used for vertical surfaces and sanding between lacquer coats.
8/12/16       #8: Sanding dust ...
Thanks again for the information. We've ordered a vacuum and will be deciding on a sander soon.
8/12/16       #9: Sanding dust ...
Sanding tables are great if you sand every day and have the room. They must be hooked up to central dust collection, or they take too much time to empty, clean, etc.
The Festool is portable, hose and electrical are integral, and the tool triggers the vacuum. The hoses are first rate. Shop vacuums (most are homeowner grade) have hoses with heavy corrugations on the interior which eats up CFM and velocity fast. Smooth is better.
The Festool vac is also very quiet, using real bearings instead of needle bearings that scream and cause hearing damage.
Festool, Fein, and maybe Mirka are all better vacuums.
