Chipped laminate edge
9/14/16
jonathan mahnken
I re laminated a conference table for my lawyer a couple of years ago and the arms of his rolling office chairs have chipped the bottom of the laminated table edge when they rock back and away from the table. This is in spite of the decent backe bevel I did to prevent this. Is there some sort of protective channel/edging I could put around the bottom edge or should I just re edge the table with solid stock
Measures.pdf
9/15/16       #2: Chipped laminate edge ...
chipbored
Would you take the whole desk off site to repair?
What about a 1.5mm x 12mm aluminium extrusion routered into the underside of the table sitting a half mm proud of the edge to protect it. You could powdercoat it black and it would look quite neat with that timber color.
On second thought it looks like the table has a slight radius. Is that correct?
(excuse the metrics)
9/15/16       #3: Chipped laminate edge ...
John McGinnis Member
We do lots of laminate tops for medical centers and have had that issue in the past. We started using a product called GemLock and it solved the issue. Basically, we order our material pre laminated. Then we cut it to size, add our build up and route a 1/4" x 1/4" groove in the edge. The GemLock is a 1/4" thick "banding" that has a small Corian top and bottom edge with laminate in between. You can choose the type of Corian and the laminate so you can use either as an accent or just make it blend in.
Sorry if this sounds like an ad but we really like the stuff and we NEVER get called back for chipped edges anymore.
GemLock Web Site
9/15/16       #4: Chipped laminate edge ...
jonathan mahnken
Thank you jon that looks like just the trick
    Lamello
