Butt Joints in countertop
10/28/16
Kevn Member
I have an upcoming island top to do, walnut, approx 12' x3' x 1-3/4. My supplier thinks they can source the 13' plus boards, but am wondering if gluing up shorter boards for length is a viable option. The homeowners don't have a preference. I am reluctant to introduce more glue joints, but it seems to be fairly common practice. Anybody do this on a regular basis?
10/28/16       #2: Butt Joints in countertop ...
Anyone who does likely uses finger joints on the endgrain.
10/28/16       #3: Butt Joints in countertop ...
I've never done it, but suspect the width and cut of the stock will make the difference. Rift and quarter sawn will be more stable and less likely to cup. Same goes for 3" wide stock compared to 8" wide.
12/13/16       #4: Butt Joints in countertop ...
Kevin Member
Ok, so looks like I'm striking out on finding the lengths I need. I may have to end up butt jointing the boards. Would dominos at this joint be sufficient, or should I look into finger jointing them? Not sure how this will look on the outside boards.
12/13/16       #5: Butt Joints in countertop ...
Pete D
I haven't done a top with butt joints, but I would think dominoes or a floating tenon would be stronger than a finger joint since the mortise is deeper and uses more of the face/edge grain.
I use a variation of a finger joint for a glue joint cutter on edge grain with two interlocking fingers that have a depth of 2.5mm. The joint is harder to see if the mating boards have a similar color tone. If the two boards are more varied in tone the joint is pretty visible. If you use a finger joint, match boards with a similar tone on the perimeter.
12/13/16       #6: Butt Joints in countertop ...
Pete D
Second thought... the "strength" of these butt joints is not a big deal in the sense that all the boards are edge glued locking in most of the butt joints. The main benefit for using a finger joint is keeping the mating edges in alignment, which it excels at, especially for wider boards with a greater tendency to cup/bow. If the stock is narrow there will be less tendency for a mild cup/bow to highlight the joint and dominoes would probably be fine although I'm not sure they're the best solution for this application.
12/13/16       #7: Butt Joints in countertop ...
Kevin Member
Thanks. I was thinking the dominoes wouldn't show from the edges, and that might be preferable. I'm mainly concerned about the glue joint opening as the boards move. This island will have an undermount sink, so I really didn't want a whole lot of joints everywhere.
12/13/16       #8: Butt Joints in countertop ...
Pete D
Double check the MC of the lumber you're using. If all the boards have a similar MC and the top is fastened to allow seasonal movement, I wouldn't worry too much about the joints opening up.
