Butcherblock Shrink
10/29/16
nyc_sport
I bought two 8 foot, 2" thick butcher block tops for a workbench. One of them had some warping, but has largely subsided after a few days in my house. But this top is thinner -- by almost 1/8" -- than the other top, which is spot on 2" thick. I would have expected the butcherblock to be pretty stable across the thickness. Could this be from moisture and should I hold off sealing this top? Hard to imagine it was built that far off -- it came from a well known butcherblock outfit. Thanks for any thoughts.
10/30/16       #2: Butcherblock Shrink ...
Mike Member
I would think that even if one was face grain and the other was edge grain that 1/8 would still be to much for 2 inches they must have been made that way in my opinion.
10/30/16       #3: Butcherblock Shrink ...
nyc_sport
Thanks Mike. I guess it is time to improvise. This photo gives you an idea how far off the two slabs are.
10/30/16       #4: Butcherblock Shrink ...
the google
Which well known outfit?
We specialize in custom wood tops, but ordered a finger-jointed top (from what do ghost say) company. This is what the customer wanted and not a style that would be easy for us to replicate. The order came in wrong to start but the replacement tops were 1 7/16 to 1/32 less than the 1 1/2 thick we ordered. Out of four tops, all of the thicknesses varied, and would have been noticed if we did mill them more. It was not a plug and play situation for sure.
From my experience, I would say your tops were milled to different thicknesses. I wouldn't anticipate any substantial changes as the seasons change.
10/30/16       #5: Butcherblock Shrink ...
JR Rutter
Sounds like a production policy of "sand it until every stave is leveled off" rather than "sand it to 2 inches thick"
10/31/16       #6: Butcherblock Shrink ...
I'm sure if you needed two identical thickness tops, just ask them. Otherwise, you get just what JR said. No way kiln dried stock that wide can shrink 1/8", and no way is this a defective top. Just a different machining tolerance than you expected.
