MELAMINE SAW BLADE
11/29/16
chris
Hello guys, i have a melamine closet to make up for a customer. i dont normally deal with melamine (i hate it).
I dont have a table saw with a scoring blade so can anyone recommend a good melamine saw blade?
11/29/16       #2: MELAMINE SAW BLADE ...
Mitch Suber  Member
Website: subercustomshutters.com
If you search this site for "melamine blades", you should get a good bit of information where this has been discussed several times.
A short answer is I have been getting very good and acceptable results using the Freud Double Sided Melamine blade on my table saw, with minimum tweaking. They usually run around $90.00 to $110.00, I got my last ones from Amazon. Also from Woodworkers supply and similar supply sources.
12/1/16       #3: MELAMINE SAW BLADE ...
Harold morantz
Any good quality triple chip tooth blade will do the job, especially if you have scoring. We cut mostly melamine and high gloss acrylics and they do a perfect job. Sharpened weekly.
12/2/16       #4: MELAMINE SAW BLADE ...
chris
Thanks guys!
