34 1/2'' or 34 3/4''
2/5/17
Eddie
Here in Northeast most of stone counters are 1 1/4'', so designers and architects are calling for 34 3/4'' cabinets, leaving the face frame of inset cabinet with 30 3/4'', but now we're having problems with dishwashers, for example Bosh calls for 30 1/8'' max height for custom panels. Anybody else building at 34 3/4''?? If yes how are you dealing with this, Thanks for any inputs
Eddie
2/5/17       #2: 34 1/2'' or 34 3/4'' ...
Mark V.
Solution #1 - Ignore the people that don't have a clue
Solution #2 - Make your toe kick 4-1/4" high
I work in the Northeast and build 32mm metric cabinetry, so my standard base is 34-1/2" high (30-1/4" cabinet with a 4-1/4" toe kick). Floors are never level so somewhere in the run the countertops will be at 36", which is what your people are focusing on.
2/5/17       #3: 34 1/2'' or 34 3/4'' ...
mike
I have made some 35" high due to clearance problems with slide in ranges but making it up in the toekick does help with the dish washer
2/6/17       #4: 34 1/2'' or 34 3/4'' ...
Adam B Member
Eddie,
We have built our base cabinets @ 34 3/4" for years. We send a 3/4" top rail to be installed over the dishwasher opening which leaves a 30" tall opening. In the very rare case that the dishwasher is taller, then the top rail can be removed.
2/6/17       #5: 34 1/2'' or 34 3/4'' ...
DS
We have also been building our boxes at 34-3/4" for many years - as long as 3cm has been the predominant countertop thickness. I don't recall having any problems with appliances.
2/7/17       #6: 34 1/2'' or 34 3/4'' ...
Eddie
Thanks guys for the inputs, I think i will make my FF at 30 1/2'', toe at 4 1/4'', that way i will be able to cheat a little a make the dish panels around 30 5/16'' to 30 3/8'', Thanks again
Eddie
