PARTS CART
2/13/17
Brent Member
Wondering if anyone would be willing to share some pictures or even plans of a shop built parts cart. I need to build one for parts coming off of the edgebander.
2/13/17       #2: PARTS CART ...
If you describe what you are making it might be easier to suggest a cart. What do you want to sort to? Cabinets?
2/13/17       #3: PARTS CART ...
Brent Member
I am looking to build one that would take parts from the edgebander to the assembly table. I build frameless cabinets.
2/13/17       #4: PARTS CART ...
chipbored
Hi Bill
I posted awhile ago with this same question. Check out these two threads relating to this.
http://www.woodweb.com/forum_fdse_files/cnc/797148.html
http://www.woo
dweb.com/forum_fdse_files/cabinetmaking/801842.html
The cart I made is going well. we made the vertical posts removable, this is something I wouldn't do again as they never move and having them more rigid would be better. Having a few shelves of varying sizes is handy also. They can drop in and be removed to suit the job at hand.
The hardest part about making a cart is that unless you make very specific jobs it needs to be very adaptable. One week your making standard kitchens the next it's full of tall robes.
Someone posted making everything vertically stacked so that you can always get whatever part you want. Excellent advice. Stacking seems like a good way to force the flow of work (overheads on bottom of stack, base cabinets on top) but there is always some reason you need that cabinet on the bottom of the pile first.
2/15/17       #5: PARTS CART ...
Kevin Jenness
You may have some special requirements that call for a shop-built unit, but these are quite versatile and rugged.
ready made version
2/15/17       #6: PARTS CART ...
This is how we sort parts off the CNC through the bander and boring machine. The height and depth should be specific to your product. We also have small parts which is why we have the bottom compartment.
Notice the wheels. That makes it easy to maneuver and it rolls well. Wheels now are cheap.
These were made in house.
Good luck.
View larger image
2/15/17       #7: PARTS CART ...
Brent Member
Thanks For the ideas!
    Lamello
