1 1/2 thick end panels
2/21/17
Andy Drahota
Website: facebook.com/drahotawoodworks
As trends change, I have people asking for 1 1/2 thick end panels on euro cabinets. Short of laminating to sheets and banding, does anyone else have any insight? Weight seems to be a concern as well. Thanks
2/22/17       #2: 1 1/2 thick end panels ...
JM
If you are going to band, make sure its thick. The seam from the laminated panels can show through.
We now mitrefold the panels. We use a door for the outside with one edge cut at 45, use a panel with one edge at 45, glue the panel and door together, then make a triangle wedge to fill in.
Its not a big deal to do it this way, can be a little time consuming, just make sure to charge for it.
Doing it with thin banding is asking for repair/warranty work. You may think its cheaper now, but it will get expensive if you have to replace people panels at no cost.
2/22/17       #3: 1 1/2 thick end panels ...
Jared
I do 1-1/2" thick end panels as a standard. For painted work, we'll take a full size 3/4 thick end panel and add a 4" wide buildup at the front edge, and another a few inches away from the rear edge, then we run it through the bander with some 1.5mm thick maple veneer on a coil. The banding's thick enough that we can put a 1/16 radius on the front edges, and strong enough to take a beating. For veneer or stain grade, we'll replace the maple with a matching species.
