Induction Cooktop cutout
2/27/17
Kevin Member
I am laying out a kitchen in which the homeowner is requesting a drop-in induction range at the end of a run of cabinets. My concern is the small amount of countertop to the the left of the cutout. Space is already tight, so I can't really enlarge the box. Looks like there will be a 2-3" strip of countertop. I thought I remember seeing a code saying there needed to be 10-12" to either side of a range. Tops are going to be granite at this point. Can anyone point me towards some codes or standard practices?
2/27/17       #2: Induction Cooktop cutout ...
Mark B
I did a similar job a few years ago with basically the same set-up. It was inspected and was not a problem - at least not in my area.
I think that the restriction on side clearance is relative to flammable material, i.e a cabinet side. If you think about it, you have the same clearance as at the back. In my case both the back and side were tiled.
I would think that the induction feature makes it even less critical since there are no hot burners.
All just my opinion. You should probably check with your local inspector rather than having an issue later.
2/28/17       #3: Induction Cooktop cutout ...
Leo G
Have them insert steel reinforcement on the underside of the counter. They'll grind a slot and put the steel in there and fill it up with epoxy. This will help it from being brittle.
On the aspect of having enough space to the left and right of the cooktop call up your local official at the town hall and ask the building inspector what you have to have for counters near the cooktop. I don't think it'll be an issue.
2/28/17       #4: Induction Cooktop cutout ...
Kevin Member
Thanks for responses. The concern is definately more about the top breaking than the usable space next to the range, though I will check on that. I think I'll be able to enlarge the box enough to make it work.
2/28/17       #5: Induction Cooktop cutout ...
Mark B
It's been a few years, but I think that in the case that I cited, the narrow pieces behind and to the side of the cook top were separate pieces and seamed on-site.
