too much clamping pressure - starved joints?
3/17/17
the google
we're experiencing a strange happening in the shop this week and i wanted to get a little feedback.
first off, i understand that there can be too much clamping pressure applied that squeezes out all of the glue and starves the joint. however, what is a good barometer for applying just enough pressure? most of our glue ups are done in our jlt panel clamp and we tighten until we cannot tighten anymore (hand screws, not impact driven).
we glued up a 5" thick walnut end grain top this week that has fallen apart. i don't suspect improperly dried material as we used new wood as well as wood that has been in the shop for some time.
temperature might have something to do with it, but our shop is 65* during the day and 55* at night. this could drop to 45* where our clamps are, but i cannot imagine it getting any colder than that. night time temps have been around freezing this week.
so multiple edge grain glue-ups, then two separate end grain glue ups (all in our panel clamps) and then one glue up with pipe clamps to create the overall size. we didn't notice any issues until after the final glue up (we let it sit for 48 hours with the clamps attached - we just didn't have any time to work on it). for all of the glue ups - these were done during the day and left in the clamps overnight (14-18 hours of dry time). we'd wide belt them from there and prep for the next glue up.
this isn't our first top like this, but the first time we've experienced any issues like this. of 25-35 "rows", there is one that doesn't show any type of joint separation, so the whole thing is falling apart. 90% of our separations (maybe 40-50 total, out of approximately 350 individual pieces) are at a glue joint. we have a handful that have separated at the joint in one row and then caused another block in the next row to split in half.
maybe bad glue? we're using titebond 2. we keep it off the floor, but in our general work area.
any thoughts? we've not experienced this before and have been clamping, gluing, etc. for 10+ years like this without significant issues. we have had occasional separations at the joint but nothing like with this top. the strangest part is that everything looked good until the final block was examined before it was unclamped (approximately 4-5 days after the initial glue ups).
3/17/17       #2: too much clamping pressure - starve ...
I would want to test the moisture in the wood. We test all material when is comes in.
My second guess would be the glue is suspect.
Finally "as tight as you can" sounds too tight. We use the same clamps with thinner material and we are no way near "as tight as you can"
I love to hear the resolution when you figure it out.
Good Luck
3/17/17       #3: too much clamping pressure - starve ...
TB III will loose 70% of its strength at 160 degrees F. So if you used it, I would suspect the wide belt heated the joints and weakened them to failure.
Beyond that, I would have to say bad glue and/or starved joints.
If it is any consolation, I have asked for over 40 years how much pressure is the right pressure re pipe clamps, bar clamps or handscrews, and never gotten anything that could be called an answer.
3/17/17       #4: too much clamping pressure - starve ...
the google
david and bill,
my thoughts are bad glue, but we work from 3-4 ketchup (squeeze) bottles and these may contain glue from 1-2 different gallon containers. i've never experienced bad glue before so this is totally new.
as for pressure, we can have sprung joints in longer glue ups that do require good pressure to close up. our "tighten until it cannot be tightened any more" is maybe a full turn past snugged pretty good. i know these are all very official terms:)
the big part of the mystery is all of this happening well past when the glue should be cured.
for the widebelt - we just had it tuned by adam west of surfprep (he's great). we're aware of having hot parts exit the machine and these aren't typically anything more than warm to the touch (and that's occasionally).
3/17/17       #5: too much clamping pressure - starve ...
Leo G
Most yellow glues dry within an hour. So if you clamp something up at the end of the day and turn off the heat then you shouldn't have a problem. By the time the shop cools down enough to cause glue problems the glue is dry.
What is the temp of the glue when you are spreading it? If your shop is getting to 45 at night, the glue will also be at 45 in the morning. The gallon will warm very slowly. It might not even make it to 60 by the end of the day.
You should be clamping just enough for the joint to come together and get glue squeeze out. There is not benefit to torturing the wood with excessive pressure. On a pipe clamp, usually when the clamp stops turning with light pressure, another 1/2 turn or so should do it. No need to put gusto into it.
Also with yellow glue, it is nearly impossible to put to much pressure on the joint. The glue joint is usually no more than .002" wide. If you are working with epoxies, then this can become an issue.
3/17/17       #6: too much clamping pressure - starve ...
the google
leo,
if i understand you correctly - you doubt we're putting too much pressure to it? what would you suspect then?
the thermostat is set to 65* from 9am to 5pm. it cuts down to 55* from 5pm to 9am. i'll have to pick up a thermometer to measure the temps by the glue and clamps. although, we usually glue at the end of the day so the glue should be pretty well warmed.
3/17/17       #7: too much clamping pressure - starve ...
We recently moved to a new building and installed new heat in the building. It got me researching shop heat. I came across this from the wood web.
Pay attention to the portions Gene contributed. Because of this our heat is at 65 during the day and between 60 and 63 at night. I am just trying to avoid problems.
Shop heat
3/17/17       #8: too much clamping pressure - starve ...
I know this is always met with disagreement at the hands of years of experience but there was a very good article in FWW several years back that use to be free on their site but has now been moved to the paid version it seems. But that article covered in detail the specific amounts of clamping force an array of different clamps could apply and then showed graphically how many clamps you would have to use to adequately clamp an average joint and the clamp spacing was so close that virtually no shop I have ever been in would possibly be over clamping their joints. The end result of the article was, as I recall, that with average clamps (being anything from an F clamp, to a pipe clamp, to an I bar) there is no physical way you can over clamp (starve) a long grain joint.
I dont have the years all of you do but in 20+ I have put every ounce of clamping force on every long grain joint I can and never had a problem. Now a cope and stick or M&T, no, but long grain to long grain that has been the rule for us. I wish could link to the article because unless David has seen it and discounted it, it may be a bit of the information your looking for.
No answer to original problem but when we have done large end grain glue ups (edge glue, cut, flip 90 degrees, glue up) I have noticed that excessive pressure without the use of cauls can seem to compress certain segements of the glue up more than others. This would seem to create great shearing forces within the block after glue up but its just a guess. Softer woods like Walnut would seem to be more susceptible.
3/17/17       #9: too much clamping pressure - starve ...
Joe Knobbe
I would look at the wood prep. I know that Dr. Gene Wengert ALWAYS says that the sawn or jointed material should be freshly cut before you glue it and that you need to make sure if it's jointed that that material isn't "burnished". That's where I would start.
3/17/17       #10: too much clamping pressure - starve ...
With regard to glue starvation, I did a test on six identical joints of cherry 6" x 1 1/2". Two each of light clamping with heavy Jorgensen 12" clamps, regular clamp force and as tight as possible with three clamps (what I would consider excessive force). I left the joints to cure overnight. When I broke the joints by splitting them with a chisel in the end, the lightly clamped joints failed easily with very little wood failure. The regularly clamped joints had at least half wood failure and the tight as f*** joints were the best with none of the glue joint visible. The failure drifted into the body of the wood. It is in no way a definitive test but it led me to believe that glue starvation is overstated and maybe not relevant with PVA adhesive.
When this was last discussed I seem to recall that some issues to look for are too long open time leading to wood swelling and distortion of glue surfaces, dull tooling, and too long a period between machining and gluing causing humidity related wood distortion.
One other consideration is whether a wide belt yields a decent glue surface. Wouldn't it tend to leave a crowned surface?
3/17/17       #11: too much clamping pressure - starve ...
the google
mark - i know the article with clamp placement but didn't remember the pressure part of it. i have that issue and will see about digging it out and revisiting it. i've cited the spacing part to my guys on a couple of occasions and keep our panel clamps pretty close together (maybe 3-5" of unclamped space in between each one).
we didn't and don't typically use cauls to clamp. we're working with over-sized pieces so any dents the clamps would cause are inconsequential. i'm also not sure about compression.
the large majority of the joints that have opened up are between pieces that would have been initially glued up in edge grain construction.
see the pics.
3/17/17       #12: too much clamping pressure - starve ...
the google
joints are freshly prepped via our planer for edge grain and wide belt for the end grain glue up. everything is glued up within a couple hours of being machined. the quality of the joints should be pretty good (knives aren't that old).
we use thick lines of glue instead of spreading it thin since it can take 10 minutes or so to get everything clamped up. we get plenty of squeeze out.
3/17/17       #13: too much clamping pressure - starve ...
You sure somebody didn't drop it? You have breakage and cracks in the wood. That doesn't have anything to do with glue and pressure. Maybe some of those cracks were there before you started working the wood?
3/17/17       #14: too much clamping pressure - starve ...
the google
rich,
it wasn't dropped. we glued it up on a low cart and my best employee reported the bad news. my guys don't have any problem reporting problems.
there are probably 20% of these splits not along a joint and they seem to be in line with two joints that split apart. i'm guessing the joint splits just caused enough pressure to crack some blocks down the middle. and they could have been there before. highly unlikely that we would have missed them for the sheen number of them present. plus, our edge grain glue ups were 20-30" long so unless there was some weird honeycombing going on, all of the splits should have been at either end of these pieces, resulting in more consistent and less split blocks.
we glued this up on a low cart and had pieces of dunnage beneath the clamps. this put the block 4-5" off the cart, but still within 20" of the floor. the bottom side does look better (not as many cracks) but is still far from repairable.
3/17/17       #15: too much clamping pressure - starve ...
It takes a lot to split a piece of wood from the side. You can drive a wedge in from the end and it splits easily, but try and drive it in from the side to do it. How would you get sideways pressure from a glue joint failure? No way! There should be nothing forcing the boards apart, the boards should just sit there with a little gap in the glue line. For the glue joint to fail and split the board across from it, there has to be a lot of stress in the assembly. There has to be some boards that didn't work out, and were forced into alignment. For a normal glue up, you just tighten enough to force out the air, you don't have to squeeze the hell out of it. So something is wrong with the wood before it is being glued together, or in the glue up procedure. I don't feel it is a glue issue.
3/17/17       #16: too much clamping pressure - starve ...
I agree with the other guys. I have never seen a clamped to tight pva glue line fail. It loves smooth surfaces(straight off the joiner) and thin invisible glue lines(as Leo mention .002", paper thickness at the most).
The glue joint failures from too much clamping pressure are always epoxy. It loves thick visible glue lines on rough surfaces(80 grit).
One of the best examples of this situation are curved 1/8" veneer jambs(huge bending/delam forces for doors & windows. Any interior ones we have made are done with pva. Exterior ones are always done with epoxy. I have seen several fail because the guy ratched the clamps down as tight as possible.
I'm guessing you are having two problems. TB2 hates cold temp. You can find several threads in the Knowledge base. The other is your gluelines may be too thick. It takes you so much time to get the locks together that you use extra glue and it gaps at some places and not others. The whole setup of using a hundred blocks that are perfect squares can lead to glueing problems.
Switching to epoxy resin would solve all of your problems.
3/18/17       #17: too much clamping pressure - starve ...
Two possibilities: have a look at the culprits in the glue-up. Can you identify a common board(s) from the end-grain that is failing? Imagine locking in a high moisture block around dry ones. It then shrinks quickly because of the end-grain exposure. That would create a lot of stress on the joints.
How warm was the new wood? If it was at or below freezing it would take several hours to come up to optimal gluing temperature.
3/18/17       #19: too much clamping pressure - starve ...
Im in agreement with Tom. My thought was a rogue board or two and possibly a bad luck chance that a certain combination of alignment resulted in a concentration of stress all over the part. Some of the crack seem to emanate/or terminate at the pith. You can see some concentrations of segments in close proximity that are in alignment. All just guesses.
Really sucks. Lot of work and a lot of stock value there.
3/18/17       #20: too much clamping pressure - starve ...
Kevin Jenness
" i don't suspect improperly dried material as we used new wood as well as wood that has been in the shop for some time."
That sets off an alarm bell for me. Did you check the MC of both stocks of wood? How long was the new stuff allowed to acclimate prior to use? Given usable glue and the milling and clamping procedures you have described I would suspect inconsistent MC in the lumber used or perhaps a major change in RH between storage and shop conditions.
The second photo shows a split running from one glueline extending across an adjacent block well away from a glueline. It looks like some local shrinkage is going on.What are the storage conditions for the old stock? If it was kept in the same conditions as the shop floor I would guess that the new stock included some material of a higher MC.
3/18/17       #21: too much clamping pressure - starve ...
I don't have a clue what the answer is.
Could grain direction have something to do with it?
Also what Tom states, seems like a likely cause.
How are you going to fix it?
3/18/17       #22: too much clamping pressure - starve ...
mike
looking at the orientation of your boards in your glue up , there is face grain to edge grain, all random... I would think this would cause great stress, especially if the boards all vary in moisture content...just a thought
3/18/17       #23: too much clamping pressure - starve ...
JR Rutter
My first thought is moisture content varying from piece to piece, seeing some split right through the block rather than on the glue line.
3/18/17       #24: too much clamping pressure - starve ...
If you can see the pva gluelines in a photo then they are definitely too thick.
I hadn't noticed that the top was 5" thick. Between all the difference pieces and the length of them, there is a ton of waterbased glue. Huge amount of moisture to be absorbed into the wood and slowly let go.
Any minor differences in moisture content between the old wood on the shelf and the new wood from the distributer would be exaggerated by all of this new moisture. The stuff in your shop could be 9% and the stuff coming in could be 6%.
Get a moisture meter and test the remaining scrap. People often think their shops are dry, when in fact they are not.
3/19/17       #25: too much clamping pressure - starve ...
door shop guy
I also noticed the face to edge grain is very random and we all know that alone is a lot of stresses working against each other.
My other thought is are you using a "Panel Flattner" fixture on your JLT clamp rack to pull the glueups together? I have always thought that was a terrible idea as well.
Are you prepping your stock on the jointer or just ripping and gluing?
Also i like to keep my shop a constant temp night and day all year long. For me its well worth the little bit of extra cost on the gas bill to know i wont have temp. problems. When you are dropping the temp. every night, you are letting everything get cold soaked and it takes a lot for the cores of everything to get heated back up again.
3/19/17       #26: too much clamping pressure - starve ...
I'd heard the thing about excessive clamp pressure starving the joint. I decided to test it. I fished a few pieces out of the scrap barrel that had been run though the molder, sharp knives, 30'/min, two knives per head, unjointed, so figure single knife finish. Original Titebond, shop above 65*. Bock size relatively small, a few inches. Clamping, in a hydraulic press, to it's max pressure 40,000 lb. 1" thick steel press blocks were used. Left overnight, removed from press and let sit a couple of days. Cut a shallow groove at the joint line so the steel wedge would be right on the glue line. Back to the press, forced the wedge into the glue line until something gave. The result: no glue line failure. The hard maple failed. I did 3 of these tests, same results. Everything was done wrong: not fresh surface, excessive glue, excessive pressure, extreme force on the glue line. But temperature was within specs. Open time was short. We normally glue right off the SL rip saw on a Taylor clamp, no problems. When we must glue wide thin parts for curves, we do widebelt (80g) the faces after they have been resawn on a band resaw. The laminations are made extra wide because the widebelt will always dub the edges some. Again no problems.
3/20/17       #27: too much clamping pressure - starve ...
the google
thanks for the replies and ideas.
i said this before and i'm not sure if it changes anything or not but... the majority of the open joints are between pieces that would have been edge glued together in one of our initial glue ups. these would have been glued up 2-3 days before the last glue up (3-4 days before we noticed the open joints). again, there were no signs of anything wrong until the 2 days after last glue up.
it seems like varying moisture content is likely the culprit but i'm stumped on why the delay for the joints to open up.
lastly, the bottom side (when glued was 4-5" off the bottom of a cart) shows way less open joints. maybe 15 total (vs. 40-50 on the top side). thoughts?
lastly, lastly, a few years ago we glued up a maple end grain top that was approximately 8'x 6' x 2.5" thick. it was spray finished so we sprayed the bottom one day, let it dry overnight, and were planning on spraying the top the next day. that next day was warmer and dryer. the top side (yet to be sprayed) began to curl up around lunch time. so much so that it showed a 1.5" gap when we put a straight edge on it from end to end. fearing it would break itself apart, we flooded the surface with water and the top flattened itself back out. it dried for a couple of hours, we resanded, and shot the top side. we shipped it to texas and it is still in good shape (i hear this about a year ago from the homeowner). almost none of the individual joints opened up and there were no (if i remember correctly) open joints or cracks in the top. thoughts?
3/20/17       #28: too much clamping pressure - starve ...
JR Rutter
End grain gains and loses moisture a lot faster than long grain. So any moisture differences become obvious quickly once fresh crosscuts open up what was formerly the middle of a board. With a thick end grain top, this gets magnified even more because the outer faces lose moisture and shrink while the center of the assembly is still absorbing moisture from the glue and swelling. That puts a lot of stress on the faces of the joints.
When you see parts crack through the solid wood, it is a sign that that particular piece has shrunk and the outer edges were held in place by a strong glue line.
I'm certainly no expert, but I did read Brue Hoadley's book "understanding Wood" a few years ago. It is a great resource.
3/20/17       #29: too much clamping pressure - starve ...
Your issue with more broken joints on the top surface versus the bottom is due to air movement. You let the shop temp drop at night, then crank up the heat in the morning. You are getting warm air flowing more easily over the top than the bottom so the top surface changes faster. You do this everyday to all the work in progress in your shop. Surprised we haven't heard more issues from you on table tops or solid panel doors. All this wood movement discussion is solid woodworking 101. As mentioned, read Hoadley's book!
3/20/17       #30: too much clamping pressure - starve ...
the google
rich - i'm curious as to how much room you leave under your panels. i left 4-5" for the last glue up. we would normally leave them on the clamps on a table (so 2" off the table).
i'm aware of what can happen if you leave a panel on a table top with no space in between. i figured i was allowing for adequate air flow.
3/20/17       #31: too much clamping pressure - starve ...
door shop guy
Put a piece of cardboard over things like this. It prevents the tops from overheating.
Do you have radiant tube heaters? Those are the worst.
3/20/17       #32: too much clamping pressure - starve ...
I don't leave anything near a bench after gluing up panels. I stand them up so air circulation is equal all around. Figured that out 40 years ago when I glued up some panels, took them out of the clamps, then stacked them on a bench for the weekend. The top panel was badly bowed on Monday morning.
3/21/17       #33: too much clamping pressure - starve ...
When we know that we have to seal the backside to prevent warpage on countertops or big panels. We typically spray the backside wait about 30 minutes for the finish to more or less dry. Then flip it over and spray the top. We don't care if the backside gets smudged or slightly damaged. Its amazing how quickly a panel can warp when sealed completely on one side.
Personally I would setup some sawhorses. Glue up the countertop on the bench. Lift it onto the sawhorses so that it can dry at the same rate top to bottom.
As I've mentioned a couple of times, switch to epoxy and it will solve all of your problems. What are your reasons for using TB2 in the first place?
3/21/17       #34: too much clamping pressure - starve ...
Kevin Jenness
" switch to epoxy and it will solve all of your problems"
If the problem is due strictly to uneven drying from one face to another and more rapid drying at the faces than the core, this may be true. If the issue is a mix of material with differing moisture contents and grain orientation, not so much. It's quite possible that all these factors are involved to some degree.
To the original poster, you said that you had done similar glueups in the past without problems. What changed this time? 5" is a very thick panel; were your previous ones thinner? Did you orient the grain randomly this time but not previously? Were previous examples done in a season when you didn't have hot dry air blowing over the panel? Were they glued up from one batch of consistently dry material?
Bad glue is the least likely culprit. The worst that happens to TII is congealing over time, and you would have noticed if it did not flow freely.
It seems like a moisture/uneven drying problem related to the factors mentioned above. You could reduce the risk in future by ensuring that the material is accclimated to shop conditions, keeping temp and RH stable through the process, allowing equal access to air movement both sides, orienting the blocks' grain direction consistently, making thinner slabs and using a non-water based glue. Best of luck.
3/22/17       #35: too much clamping pressure - starve ...
the google
thanks again everyone for the comments and suggestions. i've only been at this for a little over 15 years and still have things to learn.
kevin - the only real difference from before is the thickness. clamping, use of mixed-supplied wood (old and new wood), grain orientation, and glue up and finish procedure were all the same as we've been successful with previously. thickest previously was 3" teak and that's even less friendly to glue than walnut.
ironically, and if i'm understanding wood movement correctly, most of the cracks and open glue joints have closed up. not enough to make use of this piece, but you have to look pretty hard to find them. i'd think all of the swelling from water from the glue would have left when the cracks developed. our temps have been pretty steady for a week+ now and we've actually had the block closer to the heater.
adam - epoxy. we don't have any real experience with it other than filling holes, but...
expense
clean up
specific clamping pressures
these would be my objections to using it in place of tb2.
3/22/17       #36: too much clamping pressure - starve ...
Kevin Jenness
the google,
If the only real difference is thickness, that lends force to JR Rutter's comment above (#28) about the faces drying out while the core is still wet. As the moisture equalized, the cracks closed up. This would suggest that switching to epoxy would be helpful.
Be aware that the mating surfaces should be rough (sawn or sanded at 80#). In my experience that plus moderate clamping pressure gives a reliable glue joint.
The added expense of epoxy is negligible compared to the situation you have now. If you intend to stick with waterbased glue, perhaps covering the panel on both sides would slow down the surface drying sufficiently to avoid cracking.
3/22/17       #37: too much clamping pressure - starve ...
Stepanko
Hi everyone! Nobody mention glueing tactic.
I would gluing 2"x2"x8' in to slab first to wide capacity of your machine : planer or wide belt sander. Than cros sliced to 5" plank and glue it.
3/22/17       #38: too much clamping pressure - starve ...
Andrew Kreutter
We built near the exact top out of black wallnut 1 years ago. The top was fine when we installed it. Our top did the same thing after 3 months in the heating season. We sealed the top and the bottom with oil. We did everything possible to prevent any issues when we built the new top. I got the dreaded call about 4 weeks back that the top was split one morning. The splits start near glue joints but actually go across the top. I am convinced that we can not do a 6" thick end grain wallnut top. We have built many end grain hard maple tops with no issues other than the normal stuff (seal the bottom and do not dry one side faster than the other) Please let me know what the answer is to this issue. I need to replace this top again. I am thinking we will produce the top with a thick veneer, glued to a man made core to get the same look.
5/25/17       #39: too much clamping pressure - starve ...
Chad Member
All I can say is that this has happened to me before. The moisture content has to be right or you will have way to much stress on the joint for it to fail.
