using epoxy
3/24/17
the google
epoxy was recommended in place of tb2 and i'm curious how you keep the glue from sticking to your clamps (and/or leaking on your clamps and hardening)? we typically glue in our jlt clamp rack.
answers?
3/24/17       #2: using epoxy ...
Matt Calnen
I lay wax paper down on the clamp. With a clamp rack start low, work up and put card board or paper between glue ups to help keep the drizzle off
3/24/17       #3: using epoxy ...
the google
easy as wax paper? i had that thought but figured the epoxy might penetrate the wax and glue my clamps to my boards. no problems here?
3/24/17       #4: using epoxy ...
I think normal glue release will work.
Epoxy need a clean non greasy surface to stick to like everything else.
Glue Release
3/24/17       #5: using epoxy ...
Kevin Jenness
If you keep the clamp rack waxed any drips will pop right off.
3/24/17       #6: using epoxy ...
I'd say your biggest concern is over tightening on those clamps. You can starve an epoxy joint really easily. It doesn't bond like TB2. You need a nice film left in the joint for epoxy to keep it's strength. That's why it's used for gap filling.
3/24/17       #7: using epoxy ...
Keith Newton
If this is your first time to use epoxy, there are plenty of things you should know.
All epoxy is not heavy enough viscosity to use as an adhesive. If it was formulated to wet out glass fibers with the minimal resin to glass ration, it might just squeeze out of the joint with too much clamp pressure, and due to slow setting time.
So be sure to get their user manual and read it.
3/25/17       #8: using epoxy ...
Dan cook
Just curious why would you use epoxy for this. TB2 is stronger than the wood itself if done properly. Unless you have a failure maybe you are overthinking the process. Just a thought. We do use epoxy for some things, but not for gluing up panels.
3/26/17       #9: using epoxy ...
Dan,
he started a thread about too much clamping pressure. He was gluing up huge countertops out of 2"x5" hardwood blocks. The gluelines are wide, and more time is good for the glueups. Epoxy is a better choice than pva.
