Line boring confirmat
4/2/17
C-Tay Member
We have been line/ construction boring our cabinets for many years. I now want to construction bore confirmat screws, but I'm having real difficulty finding tooling. There are many step drills out there but none that fit a line boring machine. The typical boring bit sizes are 57 and 77 mm tall drills. Our Maggi will accept 85mm tall drills as well.
Is there anyone out there that has a source for custom and or stock drills?
4/3/17       #2: Line boring confirmat ...
AA
Ok,
I am on the same process hear what i Got.
Amana
ama55102
ama55103 depends on step confirmat thickens.
I called Guhdo and was told they can custom this tool to be mounted on my cnc with 10mm shank (just the 10mm and 7mm ) which I will be using for side panel drilling. But the horizontal 5mm It will B mounted on my horizontal drill machine to drill the tops and bottom.
I still searching this process and do not know if this is a good scenario.
4/3/17       #3: Line boring confirmat ...
C-Tay Member
Yeah I tried these bits, they do burn up because the chip deflection is poor. I'm having some custom HSS tooling made by Riversied Tooling made. They should be in at the end of the week, I'll let you know how they work.
4/3/17       #4: Line boring confirmat ...
AA
ok try this one, confirmat step bit 5-7 10 mm
QS12793
got this part number from a friend of mine, but he nails the side panel with bottom first and drill using this one by hand.
the side panel has 5mm cnc pilot hole.
please let me know what bits you will be using with the horizontal drilling machine.
Thank you.
4/4/17       #5: Line boring confirmat ...
Dave L
Why are you looking at step drills? Through bore the face w/ 7 (or 5) mm V point and endbore w/ 5 (or 4) mm brad point. Countersinks aren't necessary (but you can add them to standard V-point bits), neither are nibbed confirmats (hate them).
4/4/17       #6: Line boring confirmat ...
C-Tay Member
Do you have a source Dave?
4/4/17       #7: Line boring confirmat ...
C-Tay Member
I like the step drill because I don't want to swap out the drills.
4/4/17       #8: Line boring confirmat ...
Dave L
Anyone with a decent boring bit selection should have all the above, they are made by just about every company making carbide tools. A quick search turned up Amana @ ToolsToday.com. European Tooling Systems also has everything you could want, including custom bits.
I'm real curious how much you are willing to spend to not swap 5 or 6? bits once per project. Doesn't the Maggi have quick change collets? I don't see how you won't have to change something that you wouldn't have to with standard bits, e.g. drilling depth.
Amana bits @ ToolsToday.com
