Cutting straight and close
4/22/17
Dan cook
I need a way to run a motorized circular saw blade in a very straight path for 120" with the guide and blade being no more than about 4" wide. I've thought about something like an angle grinder but need some way to make it go in a perfectly straight path for 120". This would be to cut seams in veneer. Any suggestions would be appreciated.
4/23/17       #2: Cutting straight and close ...
https://www.amazon.com/Rockwell-Compact-Circular-Starter-RK3441K/dp/B00GTEU0M4
And a bought or shop made track?
4/23/17       #3: Cutting straight and close ...
Dan cook
I have this saw already. It is not a very well made or accurate saw. The concept is good, but the execution is weak. Something along this line could work if I can figure out a way to make it go in a perfectly straight line. It is for cutting veneer seams and they need to be near perfect.
4/23/17       #4: Cutting straight and close ...
chipbored
Any particular reason blade needs to be 4"?
A plunge saw with long one peice track would do the job no worries. Otherwise what about a better quality small blade saw with a home made adapter to lock onto a shop bought track.
Makita has an adapter that hooks a standard cordless saw onto one of their tracks. You could copy the principle or buy it and jig your little saw upto it.
4/23/17       #5: Cutting straight and close ...
I use a router to cut a stack of veneer at one time. I'd go shopping at a steel supplier for angle iron or small channel iron for the straightedge. Find a shop with a 10' slider and hire them to edge your veneer is another option. Sandwich the veneer in MDF to control chip out.
4/25/17       #6: Cutting straight and close ...
ted
Dan,
I'm not known for my veneering prowess, but in the past I have laid two leaves to be joined, flat butted next to each other and then trimmed them with router and straight-cut guide. Idea being that even if the cut was not perfectly straight, the joint would match. Make sense? Let me know if it is unclear.
4/25/17       #7: Cutting straight and close ...
Dave L
Why 4" wide and why a handheld saw? Veneer sandwiched between 1/4" MDF and walked through a tablesaw works well.
4/26/17       #8: Cutting straight and close ...
pat gilbert
"Veneer sandwiched between 1/4" MDF and walked through a tablesaw works well."
Can you please explain a little more on how that works?
4/26/17       #9: Cutting straight and close ...
Dan Cook
I have done the sandwich thing between sheets of boards, but it seems like unless you have enough pressure the entire length you still get tearout on some veneers. I have a way to apply pressure but I need a saw that has a narrow profile as the pressure beam is only 3" from the cut line. I use a router now and it gets the job done 95% of the time. Just thought a saw might not have tearout due to cutting angle.
4/26/17       #10: Cutting straight and close ...
Dave L
The sheets of veneer are placed between two sheets of 1/4" MDF that are at least as wide as the veneer being seamed. Angled seams can be cut if you tape the veneer to the bottom sheet. For parallel seaming, I just glue the end faces of the sandwich (temporarily clamped) with either hot-melt or yellow glue. The sandwich will stay together so long as there isn't too much unsupported flex.
I walk the sandwich through with both hands near the blade so that there is always downward pressure on the sandwich as it goes past the blade. I use a triple chip blade and take it slow and steady.
4/27/17       #11: Cutting straight and close ...
Dave L
The link should be a bit more informative (includes pics).
Seam Cutting
4/27/17       #12: Cutting straight and close ...
Thanks Dave
