Crazy table saw question
5/9/17
Mike Fuson
This is going to sound crazy...
I have a 3 hp unisaw, don't know exactly how old it is but I've used it for 18 years. The saw performs great. When I do a kitchen worth of mdf panels I put an older blade on the saw that is still sharp enough to cut the mdf with ease. When I'm done I put the sharp rip blade on and the saw seems to not have any rpm or torque. Struggles to even rip 13/16 soft maple. The next day it will be back to normal. Today I cut 3 sheets of 1/4" mdf into door panels and changed the blade and the difference in the saw was immediate. It only does this after cutting mdf, is there a reason for this or am I just going crazy?
5/10/17       #2: Crazy table saw question ...
Do you think it is not the saw but the material? And your judgement being misplaced on the saw?
5/10/17       #3: Crazy table saw question ...
JP Member
Belts slipping? Does it sound normal?
You could do an amp draw on the motor when it's hot under load and compare it the the cold motor amp draw.
Other that that, IDK.
5/10/17       #4: Crazy table saw question ...
Paul Miller
I occasionally put a lubricant on my table saw bed to help material slide. I wonder if the MDF dries out the lubricant on your bed.
5/10/17       #7: Crazy table saw question ...
Jim Clark  Member
Website: http://s51.photobucket.com/albums/f386/jcquack/Fur...
Sounds like the MDF dust is getting into
something.
Maybe belts or motor??
5/10/17       #8: Crazy table saw question ...
Mike Fuson
Thanks for the responses. Like I said, last night after the mdf it didn't have any power, tonight turned it on and it was back to normal. I did look more closely inside and one of the belts is gone, it's not even in the saw so I guess the dust collector ate it...have no idea. It's the one farthest away from the throat plate so I hadn't noticed that it had broke. The other two belts might be getting loose especially since they're doing all the work. I'm not sure how tight they are supposed to be? I might just put 3 new ones on it that are the red woven kind that look like a chain, I have one on the molder that seems to do pretty good. If they make them for it. The mdf dust might have been getting on the pulleys and belts causing them to slip like was said above. Thanks
5/11/17       #9: Crazy table saw question ...
Mitch Suber  Member
Website: subercustomshutters.com
I would bet the belts are the issue. I intentionally run just one belt on my Powermatic. One is enough to do all of our light cutting. Occassionally it does slip when cuttung mahogany and such, especially the 8/4 material. I run the one belt so twisted binding lumber will stall the blade if I get in a jam. I prefer that to having heavy boards getting tossed about by the blade, especially when my hand is so close. Every fews day I may shut the saw down, back the board out again, and make a new attempt at the rip. Also, one belt makes me and any helpers use a slow steady feed rate (we hand feed, no power feeder on the table saw). This way we get a safe cut, and a better cut too. Slower it seems yes, but not really in the long run.
5/31/17       #10: Crazy table saw question ...
Any tool that uses multiple groove sheaves needs to have matched sets of belts. Not just the "same" size. Industrial suppliers like Motion Industries can supply them.
