Commercial construction methods
6/7/17
Ron Krogstad  Member
Website: http://www.krogstadcompany.com
We have two projects, both are fed/army corps. The section view of the construction method shows vertical 2x4 at the back of the cabinet. There is a 2x4 top and bottom plate, and the plate sits on top of the deck. Basically, take a standard frame less cabinet, move the back in 3 1/2" and build a 2x4 wall at the back of the cabinet. We have submitted a RFI for clarification, but have yet to receive a response.
We have done lots of govt projects, but I have never seen this method before?
Anyone know anything about this method?
6/8/17       #3: Commercial construction methods ...
Alan F.
One of 4 things happened
1) A structural engineer designed it for some reason
2) Someone pulled a 50 year old detail out of a drawer
3) a $10 hour draftsman thought cabinetmakers use 2 x 4's when they site build the cabinets.
4 ) The architect bought a library of stock details 40 years ago.
There is no structural reason for standard casework or seismic installation.
Use AWS /NAWS standard details and ignore it unless the structural drawings show connection details with an engineers stamp
6/11/17       #4: Commercial construction methods ...
Rick Grady
I'd "love" to see a Cross Section pic of this, LOL!
6/16/17       #5: Commercial construction methods ...
Yes, we get drawings, almost, as bad. We do submittals to AWI standards. They usually go through, approved.
6/17/17       #6: Commercial construction methods ...
I am not sure if what you are describing is the same as what I am thinking, but the one company I worked for quite a few years ago did all commercial projects and many times when cabinets or reception desks ran perpendicular to a wall or were in the middle of the room they would have a wall in them.
The wall would be framed similar to a 2x4 wall except they always were built out of 3/4 inch plywood and the plywood uprights or studs always had holes in them so this way they could run all the electrical and computer and communication cables, etc in these walls. The backs of the cabinets were always removable and acted as an access panel so at anytime you could add or work on the cables. I may be thinking of something totally different but that is my experience.
6/17/17       #7: Commercial construction methods ...
Scott, that is normal practice.
6/18/17       #8: Commercial construction methods ...
I forgot to mention, like Larry said we always submitted shop drawings with details on how we wanted to build it and they were seldom rejected.
