Large MDF door ?
6/18/17
Hi
On an upcoming project I have a cabinet with double 2'x8' doors, veneer core. I suspect, a door of this size would warp immensely, so the question is how to make this cabinet to keep the full overlay look and a straight door.
Is there a company in NJ that could laminate a regular slab with supplied veneer?
Thanks,
Luca
6/18/17 #3: Large MDF door ? ...
I'd suggest veneering the doors on a hollow, torsion box, core.It would keep building the cabinet sides up for weight to a minimum; as well as reduce door weight, fewer hinges etc.
6/18/17 #4: Large MDF door ? ...
3/4'' or 1'' thick MDF with Maple Veneer. Husky have a great MDF core product.
6/18/17 #5: Large MDF door ? ...
Veneer core is an invite to a potato chip door! MDF would be more stable but heavy.
6/19/17 #6: Large MDF door ? ...
If getting it custom laid up you can use ultra light MDF for the core.
6/19/17 #7: Large MDF door ? ...
You could get MDF core plywood and edgeband it. It's readily available in most popular species. I recently got 3/4" quartered walnut from Atlantic Plywood for a little over $100 a sheet. A-grade faces and super flat. My largest door was 24x61, so I can't vouch for going to 8'.
Cheers,
Pat
