Curved and angled seat back
7/13/17
Chris
We have a job coming up that will require the back rest of a banquet to be curved and angled back. I'm a bit rusty on curved work. Last thing I did like this was a 1/2 cone shaped table base made out of bendy ply with 5 million staples and glue then veneered. Wondering if there is a better way. The bendy ply works ok, but as the curve changes, it renders the bendy ply kinda useless as the bend is no longer 90 degrees to the grain of the ply....I hope that makes sense. It's a paint grade project, so we have that. I am guessing the back is maybe 2' tall, slants back maybe 15 degrees and the curve is maybe a 2' radius. Not looking at the drawing. I'm guessing wedge shaped pieces of bendy ply will be the solve?
7/16/17       #2: Curved and angled seat back ...
With your bendy ply and all the seems you will have plus the cracky surface of the ply finishing will be a challenge!
7/17/17       #3: Curved and angled seat back ...
Matt Calnen
I did this one similar to what I think you are trying to do. This one has 2" of back angle from the top of the window sill to the top of the seat. This might not work for you if your backrest has to extreme of a curve. I used 3 layers of 1/4 inch bending plywood, then added a skin of 1/8" bending plywood with a smooth face that I glued to that for a nice smooth face( there was a seam or two that we cleaned up with bindi). I made the seat as multiple pieces. I left the seat section, the sill, and the foot area toekick board off until in the house. This allowed us to get it in, but still not have to site fit a lot of parts. I made the framing of the piece and used it as a form to shape the compound curve of the backrest. I just had a helper and myself push the plywood into shape and marked it where it would need to be cut. The seat platform covered the bottom and we ran the top slightly high and trimmed it flush after all glue ups where done. I just glued and stapled the 1/4" ply to the framing, then construction adhesived the face skin on. The thin plywood will take a compound curve. As this was a built-in type piece, we just had the house painter paint it in.
