Outlet in drawer
7/24/17
CBWW
I am building a custom free standing vanity/make up desk for a client. She wants the top drawer to have an outlet for a hair dryer. I have seen the hinged arm mechanisms form Hafele but they are to large to fit the space I have. I do not have a wide drawer box to accommodate the arm. Any other sources or ideas that would work?
7/24/17       #2: Outlet in drawer ...
You might want to consult the electrician that is going to wire it as a first step.
7/24/17       #3: Outlet in drawer ...
Have them put a regular box in the the back of the cabinet. Install another small outlet in the back of the drawer. Wire it as if its an extension cord. You wouldn't need much cord.
Think extension cord fastened to a drawer.
7/24/17       #4: Outlet in drawer ...
Marine & RV have nice black small 110v wall outlets.
7/24/17       #5: Outlet in drawer ...
Keith Newton
Rather than putting it in or behind the drawer, where the cord will be pulling over the back when the drawer opens, then hang down possibly into lower drawers in a stack, I make the drawer sides a little lower, then have the electrician put a receptacle under the next compartment, like under the sink. I then drill a big hole through the bulkhead above the drawer side near the front, so the cord can just be laid down up there with the appliance.
The electrician may be required to put a button behind the front or somewhere to avoid the fire hazard of it getting turned on while the drawer is closed.
7/24/17       #6: Outlet in drawer ...
Matt Calnen
I have had good luck putting a slim plug strip in near the top of the drawer box opening in the side of the box and using a shallower height drawer box than normal( say a 3" tall box for a 6" opening). Make sure a receptical is right at the front of the cabinet and plug into that.
7/27/17       #7: Outlet in drawer ...
Jim Clark
Why not just mount a power strip in the drawer and plug it in to a receptacle in the
cabinet.
7/30/17       #8: Outlet in drawer ...
don Member
you guys should try these. We've been using them for a couple of years
Docking Drawer
7/30/17       #9: Outlet in drawer ...
cabmaker
I agree with Don about the "docking drawer".
Is really well thought out.
7/31/17       #10: Outlet in drawer ...
ted
Definitely docking drawer
