hidden shelf pins
8/4/17
mark Member
I have removed cabinets in the past that had normal 5mm or 1/4" shelf pin boring but the pins were hidden in the edge of the shelves. They had an 1/8" slot cut into the edge of the shelf and it just slid over the pins , that were oval shaped that installed into the holes. Any idea if they are still available and where ?
8/4/17       #2: hidden shelf pins ...
Steelie Mark
The regular stamped, spoon shaped, 1/4" & 5mm pins work fine for that , just cut a flat slot with the appropriately sized router bit. I've see just drill hole recesses used too.
8/4/17       #3: hidden shelf pins ...
Dave L
Hafele 282.21.
8/5/17       #4: hidden shelf pins ...
Magic Wire
Might work
8/5/17       #5: hidden shelf pins ...
Steelie Mark
I didn't understand what you were looking for at first- Yes both the Hafele pins and Magic Wire are concealed. I use both.
I lean toward the Hafele pins as they fit a standard 5mm bore.
8/7/17       #6: hidden shelf pins ...
Jim
Swedish Shelf Clips
Hafele
