power feeder issues
9/7/17
Pat Member
I have an older 3 wheel 3/4 hp power feeder. Im having some issues with a vibration that I've determined is caused by the outfeed wheel. It seems the other 2 wheels spring up and down quite easily but the 3rd wheel is basically stuck in position. This causing too much force for the work piece passing by. From this it is actually leaving a mark in the cut as it vibrates.
Just looking if anyone has a similar issue with theirs and how they went about fixing it.
My thoughts the spring is bad? wouldn't know where to look for a replacement. Overall the feeder is working well for what I am doing so I don't want to have to replace it.
Thanks,
Pat
9/7/17       #2: power feeder issues ...
Leo G
The spring holds the wheel down. So I doubt it's bad. Likely something in the pivot area that is broken. Maybe a cracked casting, a broken bearing casing or as simple as something like a small pc of wood got stuck above the leg that pivots.
9/8/17       #3: power feeder issues ...
We just repaired our Steff Maggi 3 wheeler. One wheel was stuck up, the infeed in the usual setup. It was locked in position.
Upon disassembly, we found the wheel bushing and axle were almost locked together. No lubricant getting from the zero to the shaft appears to be the culprit. We replaced a few parts, easily found on the website, and uniformed gentleman brought them to our door a few days later. The website had great drawings and info, and made int easy to find what we needed.
Popped them in place, greased it, and all is well.
Steff Feeder Website
9/8/17       #4: power feeder issues ...
Leo G
Sounds like what I said. Feeders are pretty simple machines, moving parts wise.
9/8/17       #5: power feeder issues ...
Take it apart, determine the cause, replace what it needs, press green button!
Lots of feeds made by the same company are sold under many brand names, match pictures on the net. Comatic is probably the most common. They have a good US distributor.
