Blum Base Plates
9/23/17
Richard Member
Most of my framless cabinets boxes are made from 3/4 material. I use the Blum 120 degree clip top hinge and 0 base plate for full over lay.
I have a situation where the cabinet box is 5/8 material. The door need to have an 1/2 inch over lay. Not 1/2 overlay. I want to use the same 120 degree clip top hinge.
What base plate do I need.
9/24/17       #2: Blum Base Plates ...
Eddie
you need a thicker plate to move the door over 1/4'', use the plate # 175H9160. Same hinges and same bore distance. I said 1/4'' because you are using 5/8'' instead 3/4'', so that's 1/8'' there plus you need to overlay 1/2'', that's another 1/8'', hope you understood, but the plate number i gave you, will do the work.
