Frameless Finished Ends with Melamine Interiors
10/26/17
S Edwards Member
I don't run into this issue very often, but has anyone applied white cabinet liner to inside of alder plywood. I have staggered heights/depths kitchen with stained alder so a lot of end panels show but the customer wants white interiors.
Just wondering if the panels will warp with the interior side cabinet liner . Let me know your solutions to this issue.
Thanks in advance.
10/26/17       #2: Frameless Finished Ends with Melami ...
Leo G
I usually go the other way. Use a glue back melamine and put a veneer on the glue back side.
10/26/17       #3: Frameless Finished Ends with Melami ...
dustmaker1
As in most of the popular veneers you can get 1 side Alder and 1 side white melamine that is what we would use, $64.00 per sheet around here.
Paul R
10/26/17       #4: Frameless Finished Ends with Melami ...
Keith Newton
Ive just made melamine boxes, then made a wide panel that matches the door, which gets screwed on from inside the cabinet out.
With a full overlay door, I made the end panel as wide as wall to door front. Of course there is a false front on the end that matches the drawer fronts too.
10/27/17       #5: Frameless Finished Ends with Melami ...
Paul Miller
We glue VG laminate onto a plywood that matches the wood specie you are using. We cut our finished sides and upper cabinet bottoms from these sheets of plywood. I know this isn't a balanced board, but we have not had a real problem doing it this way and this is how I have done it since 1987.
We also offer finished end panels such as Keith Newton is talking about. But, we would still use the plywood for the underside of our uppers. Finished end panels are more money.
10/27/17       #6: Frameless Finished Ends with Melami ...
S Edwards Member
Thanks for all your input. The kitchen has two tall pantry finished ends 16" deep, 1 base FEP, the rest are uppers but show just two inches down the front of the EP, then a few inches above the lower cabinet returning to the wall. Staggered heights and depths. I thinking I'll use the dual sided material for the tall pantries, then use one sided thermofused, with the other side 'brown' ready for veneer or plam for the FEP's that only have the narrow strip showing.
The alder one side/mel other side is $85 a sheet here. I'll see how it optimizes out, I may just use that for all the FEP's, less work than cutting 3 different materials.
Thanks again.
