Add edge nosing in place, with no clamps
10/29/17
Mas Member
Would adding 3/4x1" edge nosing to a plywood counter with just nails and glue be strong enough or does the edging need to be applied with clamps?
I built 3 cabinets that sit side-by-side, all same height, but with the middle 4" deeper. I have a plywood counter that I now need to add nosing on the front edge. I had planned to route a 1/4" roundover on the trim, miter it and then nail and glue it on, sand and paint since this is all going to be painted white. I can use clamps since the top is not attached yet, but it is the mitered corners that I think I need to add in place to get them nice and tight.
10/29/17       #2: Add edge nosing in place, with no c ...
Leo G
I already told you packing tape will do the job LOL
10/29/17       #3: Add edge nosing in place, with no c ...
Packing tape works great, but don't buy the cheap stuff. 3M tape will stretch a little. Stick down one end of the tape, then stretch it a bit to stick the other end.
11/4/17       #4: Add edge nosing in place, with no c ...
Chris
Edge clamp?
https://youtu.be/lrU6NN4kCOw
