hybrid style face frame cabinet construction
11/29/17
Ryan
Our market is 90% high end custom with most of it being traditional face frame style inset doors. I know it’s a lot simpler to build euro style 32mm system but it isn’t popular where our work is. I have heard about people building a hybrid box to get simpler construction method but also allow for a tradional face frame and inset doors. I would like to know how people are doing this? Also in the process we would like to learn the best way to attach a finished face frame to a prefinished plywood box. I hear about people using pocket screws but I can’t seem to get everything to line up easily and flush out perfect.
11/30/17       #4: hybrid style face frame cabinet con ...
duster
Adding a filler between boxes can give you a good aproximation of face frame construction. We build euro style frameless cabinets and often put a 1.25" thick filler between adjacent boxes. We install them 13/16 proud of the front edges so they end up flush with the face of the doors & drawer fronts.
12/1/17       #5: hybrid style face frame cabinet con ...
Chris
Website: http://www.csaw.com/lamello/
Ryan,
We have many customers using Lamello Tenso connectors for doing exactly what you describe. The Tenso are concealed, self-clamping connectors and are part of the P-System lineup, which may be machined by CNC router or the hand-held Zeta P2. Let me know if you'd like more info.
Chris
http://www.csaw.com/lamello/p-system/lamello-tenso-p-14/
12/2/17       #6: hybrid style face frame cabinet con ...
Mike Fuson
Ryan, same here on the euro style. We do face frames but I’m not familiar with the hybrid method you’re talking about. As far as the face frame attaching goes, I hear people talking about attaching face frames to the box but that’s always seemed backwards to me. We start with the frame laying face down on a thick soft carpet that we have mounted to an assembly table. If it has a finished end panel that gets pocked screwed to the frame first, then the floor is attached to the face and then squared and screwed to the finished side. Then the other side gets screwed on to the face and then squared and screwed to the side, then toe kick and then back. Here is a couple pics of what mine looks like. Hope that helps
12/2/17       #7: hybrid style face frame cabinet con ...
Mike Fuson
I forgot to mention that in our sanding process that we round the back side of the face frame and the edge of the panel with 1/16” radius round over bit to create a groove of sort, it gives it a nice look and let’s you be a little more flexible on the alignment since pocket screws tend to pull a little.
