Tall Finish End Panels
12/1/17
Randy Stone Member
Website: http://www.dovetailconstruct.com
Hey Guys,I have some 24.75 X 90" pantry cabinets with exposed ends that require FEP's.
The pantry has a tall Shaker style door with a shorter door stacked above it ;typical of a full height cabinet.
In the past I've installed FEP's that mimic the cabinet doors and filled and painted the screw holes and gap between the FEP's so you don't see them through the gap between the panels.
I've also had this issue on lower penninsulas and at the top of lower cabinet FEP's
I'm thinking of one tall Shaker FEP to solve this issue which repeats itself several times on this job.
My question is ...Should I do this and will the center rails look odd if they don't line up? Or should I forget the gap and just stack them tight so theres no gap??
I would love to hear what do you guys do?
Paint, applied edge band??
Thanks!
12/1/17       #2: Tall Finish End Panels ...
I do a one piece panel that mimics the doors. I use a 1/8 by 1/8 groove between the "doors" to make everything match up nice.
12/2/17       #3: Tall Finish End Panels ...
Mike Fuson
I normally do an end panel that is one piece and don’t try to match it to the doors but just make the panel side itself 3 equal panels. There have been a few times that I’ve wanted to have the look that you’re talking about so I made the side a face frame and made doors for it that didn’t open, just fakes.
12/19/17       #4: Tall Finish End Panels ...
JeffM
Forget the gap...Make it one piece and if you want alignment, put a rail even to where the doors meet. That's how I would do it anyway. I also attach them from the inside through a pre finished plywood interior...No nail holes to fill.
12/20/17       #5: Tall Finish End Panels ...
ChuckC
We do it exactly like JeffM
