Belt or Disc sander recommendations
12/9/17
Annia Palmer  Member
I need to get a belt/disc sander benchtop model for my basement shop. can anyone recommend a good brand or tool that has fantastic dust collection....(these sanders produce a lot of dust.)
and if there really isn't a good brand to recommend that is 99 percent effective can anyone recommend some adaptions for a dust collector to remove any spewed dust from the sander. for example, put PVC pipe so it catches from a specific spot. and which area of a sander produce the most lose dust so I can figure out how to prevent any spilling.
12/12/17       #2: Belt or Disc sander recommendations ...
Dust collection is all about effective hoods and moving a lot of air. The velocity of dust coming off a sander is quite high do small hoods will miss much of it because it blows on by. I larger hood requires a lot more CFM.
Disc sanders are a PIA because changing discs requires messing around with stickum. I haven't looked at any of the new small belt sanders but once up on a time I had two (now) old Sears 6 X 48s. The basic machine was cast iron and OK but the very odd bearings failed quickly and were only available through Sears. The pulleys were die cast and poorly designed. I had a machine shop make new steel ones and fit proper bearings. That made those sanders OK. If you can find and old one and are willing to get it modified to work correctly it is a good solution. (Also the original dust hood on them was pretty useless.)
