upper cabinet ceiling reveal
12/10/17
Bob  Member
Using frameless cabinets with no top molding does anybody leave a small reveal between the cabinets and ceiling and if so how much. Your thoughts please?
12/10/17       #2: upper cabinet ceiling reveal ...
John Member
I've done it a couple of times and left between 1-1/2 and 2" at the top. If you leave too little any variation between the cabinets and ceiling will be glaringly obvious; a larger gap helps mask those deviations.
John
12/10/17       #3: upper cabinet ceiling reveal ...
DS
It depends on the condition of the celing. Many architects would love to see no more than 1/4" at the ceiling. But in that case attention needs to be paid to things that might otherwise be ignored, such as the thickness of can light trim rings. It may also require extra attention be paid to the ceiling, including floating the whole thing level and flat if necessary.
12/10/17       #4: upper cabinet ceiling reveal ...
Jeff Member
We typically leave a 1”gap. Nearly all of our work is commercial with drop ceilings.
On a recent job where we also put in a wood panel ceiling, I did put in a filler, though in that case there were no upper cabinets, just lowers and two full height cabinets on one side.
When uppers go wall to wall, I don’t think the gap looks bad.
12/10/17       #5: upper cabinet ceiling reveal ...
Joseph D. Christman  Member
Website: IntegrityDesignBuild.com
1" is the max gap we will leave, but that looks a little big. On residential where there is some ceiling variation, we will leave the boxes 1" below ceiling but build doors taller, scribing them to 3/8"-1/2" of the finish ceiling with a track saw. This hides the ceiling variation and is more efficient than scribing a filler.
12/11/17       #7: upper cabinet ceiling reveal ...
Bob  Member
In over 30 years of cabinet making I haven't done it.
Now I have a kitchen acrylic high gloss and client is interested in doing that. Thanks for your feedback.
12/14/17       #8: upper cabinet ceiling reveal ...
Or scribe to the ceiling(IMO it is going to look unfinished). If the soffet is out much make them fix it Before you start.
If I misread this, never mind.
