Uhling Case Clamp
3/5/18
Stewart Member
Does anyone have any experience they would be willing to share regarding the Uhling Case Clamps - good or bad? I like what I am seeing so far and intend to pull the trigger soon but due diligence first. Thanks in advance for any advice or cautions!
3/5/18       #2: Uhling Case Clamp ...
Matt Krig Member
Stewart, we use a HP3000 we picked up at auction in 2009. It's a work horse with little to go wrong. The only issue's we've had are a handful of brass air fittings getting sheared off from people leaving panels leaning where they shouldn't.
Make some 8" wide blocks to leave in the clamp that are bench height so you can slide parts through without lifting.
3/5/18       #3: Uhling Case Clamp ...
Stewart Member
Thanks, Matt! With this unit only squeezing from the side, does it tend to slightly lift at all causing an out of square clamp up? Also, do you ever use the vertical clamp attachment?
3/6/18       #4: Uhling Case Clamp ...
Matt Krig Member
We've not used a vertical attachment, nor have we had issues with lifting. I would assume any panel deflection of lifting would cease once out of the clamp.
Most important thing is to be extremely precise with CNC holes, Horizontal boring and dowel insertion and lastly, Pre-milling and edgeband/glue thickness.
3/6/18       #5: Uhling Case Clamp ...
Matt Krig Member
If you want to, you can come and assemble a job or more on the case clamp to see if they like it or not...
When there are mid-partitions, we'll just throw a bar clamp on each side since the clamp is open on each side.
3/6/18       #6: Uhling Case Clamp ...
Stewart Member
Thanks, Matt for your help - this has been very helpful! One more question, do you fasten your cabinet backs in while the case is clamping?
3/7/18       #7: Uhling Case Clamp ...
Matt Krig Member
Yes, backs get slid in while in the clamp, checked for square and fastened.
3/10/18       #8: Uhling Case Clamp ...
Brian Sager Member
I don't mean to hijack your post but how do you fasten your backs? We are looking at a Uhling as well. We can bore and cnc cut the back groove. What holds the stretchers of an upper at the top and bottom? I understand they get doweled into the sides but what do you do in the middle? It seems like it would allow the bottom to flex if the customer put anything very heavy in it.
3/17/18       #9: Uhling Case Clamp ...
Geoffrey Wirth  Member
Website: Possessionwood.com
I used my Uhling HP3000 for years, but due to changing construction methods I’m trying to sell it. I’m outside of Seattle if anyone wants to pick it up for cheap $3500. It’s been a great clamp.
