edgeband peels off
3/8/18
We are having issues with edgeband adhesion. PVC banding adheres fine but Edgemate brand fleece backed wood banding is very hit and miss. Sometimes it peels right off. Seems the Jowat J28140 glue seems to adhere to the plywood edge but not to the wood banding. The bander temp is 190-200 degrees. We have a Cehisa System 5 bander. Any ideas?
3/8/18 #2: edgeband peels off ...
We've had similar issues with edgemate banding. It seems like the fleece sticks to the glue but is not well adhered to the banding itself. You can see areas where the fleece is thicker than others, which seems to cause further issues.
3/8/18 #3: edgeband peels off ...
We had the same issue with jowat
We switched to dolken and haven't had an issue since.
You can try to prime it or preheat it also helps the glue just isn't penetrating.
3/9/18 #4: edgeband peels off ...
Website: http://www.calwoodinc.com
We had a similar issue. Long story short, Jowat was the problem. Switched to Dorus and no problems.
3/14/18 #5: edgeband peels off ...
Website: http://www.cmsrepair.com
A question for those that switched glue manufacturers, what Jowat glue were you using and what Dorus glue did you switch to?
