Trying to locate this drill bit
4/20/18
This bit is 3/16 dia, the first 1/4" is 5/32
I don't need the threaded end.
Does anyone know what this type of bit is called? Or where to get one?
View higher quality, full size image (2576 X 1932)
4/20/18       #2: Trying to locate this drill bit ...
The regular Dewalt drill bits are called pilot point.
4/21/18       #3: Trying to locate this drill bit ...
Thanks for the answer Adam
Is that bit called a bullet bit? Great for metal.
This bit is good for field work because it is fast and does not have a lot of blow out on the other side, for vinyl cabinet doors, and is easy to get into a drill bushing (on a jig for handles) without binding.
4/22/18       #4: Trying to locate this drill bit ...
Ken Member
Those are used in aerospace mfg. When Lockheed closed down their Burbank plant they had dumpsters full of drills and cutters, brand new, being sold for a buck a pound.
4/22/18       #5: Trying to locate this drill bit ...
door shop guy
You might try The Yard Store ... yardstore.com . Aircraft tools... lots of cool stuff.
4/22/18       #6: Trying to locate this drill bit ...
Thanks Door Shop Guy and Ken
4/23/18       #7: Trying to locate this drill bit ...
Paula Member
Website: http://www.creativemillwork.ca
Try this web site or do a search on drill bits for rivets.
Paula
http://knifeandguns.com
4/23/18       #8: Trying to locate this drill bit ...
Snaglpuss
Yeah, Aircraft close quarter bits, I think they are called.
I think McMaster has them.
4/23/18       #9: Trying to locate this drill bit ...
I dont know if youve found the 3/16" but I new I had seen these somewhere but this page only has 1/4" with the 5/32" pilot. May be a start.
Down at the bottom and on the second page
https://www.knifeandgun.com/SearchResults.asp?Cat=61
4/23/18       #10: Trying to locate this drill bit ...
Sorry for not seeing Paula's reply.
MSC has the 3/16"
https://www.mscdirect.com/browse/tn/Holemaking/Subland-Step-Drill-Bits?searchterm=
step+drill&navid=4287922433#navid=4287922433+4288074014&searchterm=step+d
rill
4/23/18       #11: Trying to locate this drill bit ...
Snaglpuss
https://www.mcmaster.com/#drill-bits/=1cjloxm
Here is McMaster's page for inch sizes.
Couple of dozen in there.
Called Threaded Shank Drill Bits
4/23/18       #12: Trying to locate this drill bit ...
Snaglpuss
Previous post just came up with the general page for drill bits.
Specific link here..
https://www.mcmaster.com/#threaded-shank-drill-bits/=1cjlr1z
4/23/18       #13: Trying to locate this drill bit ...
I think the ones Mark linked are the ones, albeit pricey.
Thanks for the help everyone, appreciate it.
4/24/18       #14: Trying to locate this drill bit ...
Pricey to say the least was my thought. I about died when I saw 30 bucks a bit but if you need em you need em.
