End grain to edge butt joint strength
4/27/18
Steven Member
I had to knock apart a face frame and was a little surprised by how much of the wood broke apart. I say a little because I've had to do this before, and it usually leaves some splinters but not this kind of wood breakage. This frame had only been put together an hour or two earlier, and I didn't pre glue the end grain to try and saturate it; just glue, clamp, and screw.
I know some woodworkers think a glued pocket hole butt joint will move and crack a painted finish, but from this evidence I'm not so sure. Maybe a harder wood like maple wood break apart at the joint first and only pull off a few end grain fibers, but I usually use poplar for paint grade and with the frame also being glued to the carcass this gives me more confidence that a painted finish is less likely to crack at the joint. Thoughts?
4/28/18       #2: End grain to edge butt joint streng ...
We done mostly beaded ff for 20 years. None of our frames crack. Titebond1 and pocket screws.
Typically the side grain of a decent end grain to side gain joint bonded with PVA will delam before the actual glue joint shears. The glue is substantially stronger than the natural glue holding the wood fibers together.
We only use soft maple for cabinetry. Poplar for architectural millwork.
4/28/18       #3: End grain to edge butt joint streng ...
Pat
When the paint cracks at the joint, it's not usually because of any problems with the strength of the joint. It's more likely that the glue is not fully cured prior to painting. This can take up to 7 days. I learned this from the Wood Doctor, Gene Wengert, who posts here on occasion. RF glues exist to deal with this issue.
Cheers,
Pat
