Frameless with 1/8'' reveals
7/26/18
Brett
Hey everyone,
I know this subject has been beat to death many times. We're from northern WI and frameless residential cabinets are not in huge demand up here yet. Most builders/home owners still like a face frame traditional look as I do myself. However, when we do get a request for frameless cabinets it always seems like we're going back to adjust doors and drawers constantly. The last few jobs we started doing 1/4'' reveals to try to help with this situation. We also have a wide range of temperature and humidity throughout the year which can affect the size of the doors/drawer fronts from one season to the next. Houses/interior walls also could possibly move very slightly. Doors typically are not too bad to adjust, it seems like it's the drawers that are the issue. We use undermount Pro 600 slides but it seems like when you set something heavy in the drawers the front will drop slightly. Is everyone using undermount slides or are you sticking with sidemount slides that seem to have more stability? Any other input/ideas would be appreciated.
7/26/18       #3: Frameless with 1/8'' reveals ...
Blum Tandems. I use 5/64" reveals (2mm).
7/27/18       #5: Frameless with 1/8'' reveals ...
Collin Parker  Member
Website: heritagewoodwright.com
I have used these slides for a year now, only because i bought a ton at good price... Once they are through im going back to blum. For now i have a trick, when mounting the drawer faces use a pack of 18guage nails, something heavy, to preweight the drawer slide and it will take away that sag that the vendor "swears" doesn't exist
7/27/18       #6: Frameless with 1/8'' reveals ...
Everything sags with age/use (not just hardware.) The tighter the reveal the sooner it will show the affects. 165 degree hinges are a disaster for sag. We used to use 4mm reveals but decorators thought that was too "sloppy looking." So we are back to 3mm. Except where institutional hinges are spec'd. Since almost all of our work is commercial & shipped far & wide, we rarely see it again. But I do see other's work and it often has issues with doors hitting and damaging the banding or finish. No one adjusts hinges after install, sometimes not even at install. (Residential work by local makers, maybe. 5 years down the road, not likely.) If a set of doors, kitchen floor or slight variations in original install take place to the extent of a 1/16" sag, the banding or finish will get damaged. If margins were increased to 5mm the doors would still be fine for many more years.
8/23/18       #7: Frameless with 1/8'' reveals ...
Chris
blum tandems here. movento doesnt seem any better to me. 1/8" reveals....cuz sagging WILL happen. Used to do 3/32nds
8/24/18       #8: Frameless with 1/8'' reveals ...
Anyone try hardware resources yet?
8/24/18       #9: Frameless with 1/8'' reveals ...
Jr Lee  Member
Website: http://www.leecabinets.com
Bret
I have used them(HR) for 2-3 years for some things, dovetail prefinished boxes, crown molding, undermount slides. Slides are Blum knock off I think. Occassionally get a bad one but price is great. Defects have been found before going to customer site. No problems after install. Just ordered a box of their metal box slides, soft close. I am using them in the display room to see what the customer reception is. Service is great.
Jr
8/24/18       #10: Frameless with 1/8'' reveals ...
Jr Lee  Member
Sorry Bret, I should have addressed tha response to Collin.
Jr
