New wide belt
8/4/18
Hazeltree Member
I'm using a 37" powermatic wide belt that is a war horse at this point. I'm no longer getting the consistent results with it that I am looking for. I have done a small amount of research and see both the extrema excess series 37" and the safety speed cut 37" which both would probably fit in my budget. Does anyone have any experience with either machine or any thoughts on my situation would be helpful and appreciated. Thank you
8/8/18       #2: New wide belt ...
Manu
I have the Extrema XS serie. I bought it five years ago. It has been a great machine so far just depends on what you need that for. I use mine daily and never had any problem.
8/8/18       #3: New wide belt ...
door shop guy
What in particular is wrong with the Powermatic?
8/19/18       #4: New wide belt ...
Larry Schweitzer
Widebelts are simple machines. If you had been getting good results, but not now, something needs to be fixed. Bearings, hold downs, contact drum need resurfacing or replaced, conveyor worn out, platen need new surfaces? Tracking system not working properly? All pretty easily fixed. There are sources for all of the needed parts rather than OEM.
9/10/18       #5: New wide belt ...
Adam West  Member
If you have not made a decision yet I might be able to point you in the right direction. I've worked on a couple thousand wide belts in my career. Message me if you need help.
