material thickness changing/climate control
8/31/18
Travis
Hello,
We have been noticing a thickness change in our melamine material as few as 8 hours after it has been cut. Our cnc operator said parts were fitting together too tight last night and then we tried them this morning and they fit perfect. Usually it's the other way around as the edges might swell slightly due to humidity/temperature. My questions are do you guys keep a close eye on temperature, humidity, etc of your shops? Do you leave a little more tolerance in your dadoes?
9/1/18       #2: material thickness changing/climate ...
Heat generally doesn't make a difference unless it 40-50 degrees. Humidity on the other hand makes a huge difference.
Most likely just exposing the inner core will allow it to absorb more of the atmosphere humidity.
So you either need to control the humidity in the space or make the dadoes a bit wider.
