Delta Unisaw Low voltage switch
10/2/18
KenW
We have 2 older delta unisaws which use the low voltage control system. The switches for these saws have not been made for 4-5 yrs now and are no longer available anywhere to be found, and I have just installed my last replacement that I had stashed away. Anyone retrofitted these style saws with new switches? And if so what will it entail. (one is 5hp the other is 3hp)
KenW
10/2/18       #2: Delta Unisaw Low voltage switch ...
Even Grizzly sells complete magnetic switches. If you want to stay with industrial quality, go to Graingers.
10/17/18       #3: Delta Unisaw Low voltage switch ...
Larry Schweitzer
All of the electrical supply houses will have them. Simple to install.
